If you're confident in your repair skills, use this guide to replace the heating coil in the heart of your heat gun.
Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
Remove the 8mm screw from underside of barrel using the PH#0 screwdriver.
Remove the barrel casing on either end by twisting and pulling each side off.
Remove the top casing to reveal inside of drill. You might have to tug a little harder for this one.
Remove the plastic casing from the end of the barrel.
Remove the metal casing from the heating element.
Slowly remove the heat resistant wrapping from the heating element.
crwdns2935267:0crwdne2935267:0Tweezers$3.99
Use the angled tweezers to remove the heating coil end from the input point.
Remove the heating coil by unraveling it from the heating element.
Hi,
it looks like there is a thermal fuse between the end of the blue cord and the heating element. Would it be possible to get the specifications or any other data which is written on it?
Thank you.
best wishes,
berthold
AUP0 AF133
Tf133°C G1
Silver casing, red lettering, black forward-most plastic “nose” bit
Will the gun still blow air if the heating coil is removed? I just need the air blowing function of a mini heat gun; focused air stream for crafts.
Where are the heating coil wires found?
I am asking where I can find a NEW heating coil wire?
There is continuity in the heating coil wire, so I believe something else is causing my problem. There is one terminal on the heating element
that has a curved, rigid, bulbous hotdog shaped component that is right close to the terminal on the heating element. I am not sure what it is.
One can be seen in the picture at the top of the page in the introduction.
