Drift HD 720 LCD Screen Replacement
  1. Drift HD 720 LCD Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Drift HD 720 LCD Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the back plate counterclockwise until it comes off.
  2. Drift HD 720 LCD Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the black battery tab next to the battery to get the battery out.
    • Remove the battery.
  3. Drift HD 720 LCD Screen Replacement, LCD Screen: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove six 8mm long Philips head screws with the J0 Philips head from the outer case.
  4. Drift HD 720 LCD Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back case from camera body.
  5. Drift HD 720 LCD Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the battery housing from the camera body.
  6. Drift HD 720 LCD Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use J0 Phillips head to remove two 6mm long Phillips head screws from the motherboard.
  7. Drift HD 720 LCD Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motherboard (green) from the front case housing.
  8. Drift HD 720 LCD Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the J0 Phillips head screws to remove two 5mm long Phillips head screws from the plastic bracket holding LCD in place.
  9. Drift HD 720 LCD Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the LCD screen from the front cover.
  10. Drift HD 720 LCD Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the black bar toward the LCD screen in order to remove the screen from slot.
  11. Drift HD 720 LCD Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the LCD from motherboard.
Hector Rodriquez
crwdns2935283:009/23/15crwdne2935283:0
422 crwdns2915208:0crwdne2915208:0
Baylor, Team 10-16, Williams Fall 2015 crwdns2935289:0Baylor, Team 10-16, Williams Fall 2015crwdne2935289:0
BU-WILLIAMS-F15S10G16
Did you now where to find the replacement LCD screen? Thanks.
Rodrigo Forrequi - crwdns2934203:0crwdne2934203:0
need a ribbon for stealth 2 any ideas?
dennis - crwdns2934203:0crwdne2934203:0
Good job! That guide indeed helped me a lot to give my Drift HD a good cleaning. Was a bit tough to remove the PCB, but after some fiddling it worked. Should be mentioned that you can remove the microphone from the surrounding rubber gasket so you can wash the gasket with ordinary soap. You can also separate the two PCBs (they are just stacked ontop of earch other using press-fit connectors)for easier access, e. g. if you want to clean and re-grease the collar of the lens unit. Also keep an eye on the aluminum cooler star. It has some heat conduction compond on it that you want to spread evenly. Don't wash it off entirely!
Volker Bartheld - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 1,272
