Dremel 8220 Power Switch Replacement
crwdns2942287:0crwdne2942287:0This guide will show you how to open up your device. You will then have access to all the internal components. The power switch can then be replaced with minimal effort
Locate the battery at the back of your Dremel. Firmly grasp the battery on both sides and pull. It should easily come out of the battery well.
Remove the ring located around the speed selector switch by pulling apart on either side. This should require very minimal force.
Remove the collar wrench by pushing the gear lock button. Continue to hold this button as you rotate the wrench counter-clockwise until it is removed.
Remove the metal clasp from the battery well. This piece helps hold the plastic shell of the device together. Pry it out by gently applying some force with a screwdriver.
Remove five T9 Torx screws from the side of the tool.
Remove the faulty power switch. It should come out of the device without using any force.
you solved my problem, my Dremel is real new i’m surprised it quit working oh well thanx for the help buddy see ya next time……Ricky t.
Thanks for this! I had an issue where the internal switch wasn’t releasing, it was stuck on all the time. The only way to turn it off was to yank the battery out. A little spray PTFE lube after following this guide and now it’s good as new.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
