Dremel 8220 Power Switch Replacement
  1. Dremel 8220 Power Switch Replacement, Power Switch: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the battery at the back of your Dremel. Firmly grasp the battery on both sides and pull. It should easily come out of the battery well.
  2. Dremel 8220 Power Switch Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the ring located around the speed selector switch by pulling apart on either side. This should require very minimal force.
  3. Dremel 8220 Power Switch Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the collar wrench by pushing the gear lock button. Continue to hold this button as you rotate the wrench counter-clockwise until it is removed.
  4. Dremel 8220 Power Switch Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the metal clasp from the battery well. This piece helps hold the plastic shell of the device together. Pry it out by gently applying some force with a screwdriver.
  5. Dremel 8220 Power Switch Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dremel 8220 Power Switch Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dremel 8220 Power Switch Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove five T9 Torx screws from the side of the tool.
    • Now pull apart the plastic shell of the device. If you are not able to, review the previous steps as you may have missed one.
  6. Dremel 8220 Power Switch Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the faulty power switch. It should come out of the device without using any force.
    you solved my problem, my Dremel is real new i’m surprised it quit working oh well thanx for the help buddy see ya next time……Ricky t.
    Richard Tyrholm - crwdns2934203:0crwdne2934203:0
    Thanks for this! I had an issue where the internal switch wasn’t releasing, it was stuck on all the time. The only way to turn it off was to yank the battery out. A little spray PTFE lube after following this guide and now it’s good as new.
    Frank Gore - crwdns2934203:0crwdne2934203:0
Shailing Santiago
crwdns2935283:003/08/16crwdne2935283:0
391 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-8, Isaacson Spring 2016 crwdns2935289:0UMass Dartmouth, Team 2-8, Isaacson Spring 2016crwdne2935289:0
UMASSD-ISAACSON-S16S2G8
crwdns2942667:0crwdne2942667:0 2,162
