Dremel 7300 MiniMite Cordless Collet Replacement
  1. Dremel 7300 MiniMite Cordless Collet Replacement, Collet: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dremel 7300 MiniMite Cordless Collet Replacement, Collet: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dremel 7300 MiniMite Cordless Collet Replacement, Collet: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The device comes with a small black wrench to tighten the collet nut, during reassembly or changing the bits.
    • Press the blue button and hold it down.
    • Unscrew the collet nut, with your fingers (as if you were going to change the bit).
    • Continue until the collet nut comes completely off of the Dremel.
  2. Dremel 7300 MiniMite Cordless Collet Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dremel 7300 MiniMite Cordless Collet Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dremel 7300 MiniMite Cordless Collet Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Once the collet nut is off, you can remove the collet. It is the silver part that grips the bit when the collet nut tightens on it.
    • The collet itself may be in the shaft, or come off with the nut.
Kat
crwdns2935283:002/10/16crwdne2935283:0
864 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 3-4, Sullivan Spring 2016 crwdns2935289:0USF Tampa, Team 3-4, Sullivan Spring 2016crwdne2935289:0
USFT-SULLIVAN-S16S3G4
Too anyone having trouble unscrewing the collet, you may want to clamp vice grips on if its stuck tight. Worked for me.
Will - crwdns2934203:0crwdne2934203:0
I easily removed the bit by holding the blue button and using the black wrench to loosen it and then I remove the silver piece that holds the bit then when I tried to use another one of the attachments it seems like it’s too large to fit in there I haven’t been able to use any of the other attachments like polishing and the finer little grinders
Kate Denkers - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 32,879
