Dremel 4000 Shaft Lock Pin Replacement
  1. Dremel 4000 Shaft Lock Pin Replacement, Back Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dremel 4000 Shaft Lock Pin Replacement, Back Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Start by removing the housing cap by unscrewing it.
    • Next, unscrew the now exposed collet nut while holding down the shaft lock button.
    • To remove the collet nut, you may need to use the small open-end wrench provided with the Dremel.
  2. Dremel 4000 Shaft Lock Pin Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your hands, carefully remove hanger from casing.
  3. Dremel 4000 Shaft Lock Pin Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dremel 4000 Shaft Lock Pin Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the brush caps (one on each side) by using a flathead screwdriver bit.
    • The brush caps are spring loaded.
  4. Dremel 4000 Shaft Lock Pin Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Torx 15 screwdriver tip, remove the 5 screws (12.5 mm) that hold the casing together.
  5. Dremel 4000 Shaft Lock Pin Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic opening tool to gently wedge apart the hard plastic threads.
  6. Dremel 4000 Shaft Lock Pin Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your hands to carefully remove the back casing so that none of the components fall out.
  7. Dremel 4000 Shaft Lock Pin Replacement, Shaft Lock Pin: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If the shaft lock pin is not engaging the rotary gear, or if the spring is missing or damaged, it will need to be replaced.
    • Remove the damaged shaft lock pin and spring by hand.
    • Place new shaft lock pin so that the spring functions and the lock engages the rotary gear.
John Cobb
crwdns2935283:001/20/16crwdne2935283:0
1,800 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 15-4, Remmell Spring 2016 crwdns2935289:0USF Tampa, Team 15-4, Remmell Spring 2016crwdne2935289:0
USFT-REMMELL-S16S15G4
crwdns2935297:017crwdne2935297:0
These instructions are idiotic! I want to replace the shaft lock pin because it is not WORKING. Step 1 instructs me to use the shaft lock pin to remove the exposed collet nut. The reason I am changing the shaft lock pin is because it won’t hold the shaft for loosening the collet nut. DUH!
mitchthane - crwdns2934203:0crwdne2934203:0
three years later and I came to the same conclusion: DUH
Randy Martin -
Four years later and I came to the same conclusion: DUH
Ben simon -
crwdns2936753:07crwdne2936753:0 31
crwdns2936753:030crwdne2936753:0 125
crwdns2942667:0crwdne2942667:0 13,972
