Dremel 4000 Power Cord Replacement
  1. Dremel 4000 Power Cord Replacement, Back Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dremel 4000 Power Cord Replacement, Back Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Start by removing the housing cap by unscrewing it.
    • Next, unscrew the now exposed collet nut while holding down the shaft lock button.
    • To remove the collet nut, you may need to use the small open-end wrench provided with the Dremel.
  2. Dremel 4000 Power Cord Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your hands, carefully remove hanger from casing.
  3. Dremel 4000 Power Cord Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dremel 4000 Power Cord Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the brush caps (one on each side) by using a flathead screwdriver bit.
    • The brush caps are spring loaded.
  4. Dremel 4000 Power Cord Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Torx 15 screwdriver tip, remove the 5 screws (12.5 mm) that hold the casing together.
  5. Dremel 4000 Power Cord Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic opening tool to gently wedge apart the hard plastic threads.
  6. Dremel 4000 Power Cord Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your hands to carefully remove the back casing so that none of the components fall out.
  7. Dremel 4000 Power Cord Replacement, Power Cord: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dremel 4000 Power Cord Replacement, Power Cord: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To clear access to the electrical assembly, remove the variable speed dial cap and blue power lever, and set them aside.
  8. Dremel 4000 Power Cord Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your fingers, carefully pull the circuit board from the casing. This will make it easier to remove the power cord.
  9. Dremel 4000 Power Cord Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Each wire is fed through a small opening on the circuit board and held with a flat head screw.
    • Loosen the screw just enough to remove the wire by gently pulling it with your hand.
  10. Dremel 4000 Power Cord Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove both wires from circuit board with your hands.
    • Take careful note of which side has the black wire and which has the white wire.
crwdns2935229:05crwdne2935229:0
John Cobb
crwdns2935283:001/20/16crwdne2935283:0
1 800 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 15-4, Remmell Spring 2016 crwdns2935289:0USF Tampa, Team 15-4, Remmell Spring 2016crwdne2935289:0
USFT-REMMELL-S16S15G4
crwdns2935297:017crwdne2935297:0
Super handy guide after my guide dog decided to chew through the cable!
Geoff Palmer - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 39
crwdns2942667:0crwdne2942667:0 6,395
