Dopo Double Power 7 Motherboard Replacement
  1. Dopo Double Power 7 Motherboard Replacement, Rear Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The rear panel is secured to the front case and can simply be pried apart without damage.
  2. Dopo Double Power 7 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully, wedge the plastic opening tool in-between the seam that separates both halves of the tablet.
  3. Dopo Double Power 7 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Run the plastic opening tool along the seam looking for the clips and lift up on the rear panel.
  4. Dopo Double Power 7 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The rear panel should come completely off.
  5. Dopo Double Power 7 Motherboard Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove any static tape covering the motherboard.
  6. Dopo Double Power 7 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dopo Double Power 7 Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the flat end of a spudger or tweezers, remove the three cables connected to the motherboard.
    • The cables can be disconnected by lifting up on the black section of the socket, as shown by the arrow.
    • Once the lever is lifted, pull out the cable by gently tugging on it.
  7. Dopo Double Power 7 Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips Head Screwdriver size 0, remove the four screws attaching the motherboard.
  8. Dopo Double Power 7 Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dopo Double Power 7 Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using wire cutters, cut the red, black, and grays wires.
    • The motherboard can now be removed
    • Leave enough wire to be re-soldered back if possible.
mike pelosi
crwdns2935283:010/30/15crwdne2935283:0
682 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-2, Miles Fall 2015 crwdns2935289:0UMass Dartmouth, Team 1-2, Miles Fall 2015crwdne2935289:0
UMASSD-MILES-F15S1G2
crwdns2942667:0crwdne2942667:0 588
