Dopo Double Power 7 Battery Replacement
    1. Dopo Double Power 7 Battery Replacement, Rear Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • The rear panel is secured to the front case and can simply be pried apart without damage.
    2. Dopo Double Power 7 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully, wedge the plastic opening tool in-between the seam that separates both halves of the tablet.
    3. Dopo Double Power 7 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Run the plastic opening tool along the seam looking for the clips and lift up on the rear panel.
    4. Dopo Double Power 7 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • The rear panel should come completely off.
    1. Dopo Double Power 7 Battery Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Cut only the red and black wires attaching the battery to the motherboard.
      • Be sure to remove any remaining wire attached to the motherboard.
    2. Dopo Double Power 7 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using a metal spudger, carefully pry the battery away from the digitizer.
      • Be careful to not damage the battery. This could result in injury.
    3. Dopo Double Power 7 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using wire strippers, strip the ends of the red and black wires connected to the the new battery back about a 1/8".
      • Twist the strands of the spliced wire together.
      • Using a soldering iron, apply heat to one bare wire connections you have just made.
      • When the connection is hot enough melt solder on the opposite side of the wire to the iron as shown in the image. Do not melt to much solder.
      • Once connection is made wait for it to cool off and gently pull each side of the wire to test durability.
      • Repeat this process with the other wire.
      • If you do not have access to a soldering iron, leave the old battery wires attached to the motherboard and simply splice the new battery's wires to them.
      • This video provides basic instructions for splicing wires using crimping and heat shrink technique.
mike pelosi
crwdns2935283:010/30/15crwdne2935283:0
682 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-2, Miles Fall 2015 crwdns2935289:0UMass Dartmouth, Team 1-2, Miles Fall 2015crwdne2935289:0
UMASSD-MILES-F15S1G2
crwdns2942667:0crwdne2942667:0 1,354
