Door Latch Sliding Metal Bolt Replacement
  1. Door Latch Sliding Metal Bolt Replacement, Sliding Metal Bolt: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Door Latch Sliding Metal Bolt Replacement, Sliding Metal Bolt: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the screwdriver, remove all the screws from the latch.
    • Remove the latch from its position.
  2. Door Latch Sliding Metal Bolt Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Door Latch Sliding Metal Bolt Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Check for a reinforcement metal strip.
    • If your latch does not have a metal strip at the back, then you may skip this and proceed to the following step.
    • If your latch does have the metal reinforcement strip, use pliers to tilt the strip to allow the metal bar to slide out. Apply minimal force to avoid breaking/tearing the metal strip.
    • Tearing the reinforcement strip might hinder your entire replacement and could lead you to replace the latch with a newly bought one.
  3. Door Latch Sliding Metal Bolt Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Door Latch Sliding Metal Bolt Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the sliding metal bar and replace it with another one.
    • The removal will be tricky depending on a variety of latch sizes. If the bar does not come out easily, try tilting in different angles and directions to smoothly pull the sliding bar out.
  4. Door Latch Sliding Metal Bolt Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Door Latch Sliding Metal Bolt Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the newly replaced sliding bar is installed successfully, bend the reinforcement metal strip back to its original shape using as minimal force as possible to avoid breaking the strip.
  5. Door Latch Sliding Metal Bolt Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Door Latch Sliding Metal Bolt Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Door Latch Sliding Metal Bolt Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Reposition the latch back to its original location and ensure that it is accurately placed. Take as much time as needed to make it accurate.
    • Reattach the screws back to the latch.
    • When screwing, insert each screw into the latch but do not fully tighten them until every screw is inserted.
    • Tilt the latch slightly and try to keep it in line with its front plate piece.
  6. Door Latch Sliding Metal Bolt Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once you ensure that every thing is intact, fully tighten the screws into the latch and it should work perfectly as new.
Moustafa Abdelkarim
crwdns2935283:001/31/25crwdne2935283:0
133 crwdns2915208:0crwdne2915208:0
York University, Team 2-12, Woodhouse Winter 2025 crwdns2935289:0York University, Team 2-12, Woodhouse Winter 2025crwdne2935289:0
YORK-WOODHOUSE-W25S2G12
crwdns2942667:0crwdne2942667:0 190
