Display and Camera Cables Disconnection
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Display and Camera Cables Disconnection, Prepare your Macbook Air for disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Display and Camera Cables Disconnection, Prepare your Macbook Air for disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Display and Camera Cables Disconnection, Prepare your Macbook Air for disassembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Allow your MacBook's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully power off your MacBook.
    • Close the display and lay your MacBook upside down. Keep your laptop closed until you've physically disconnected the battery.
  2. Display and Camera Cables Disconnection, Unfasten the lower case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Display and Camera Cables Disconnection, Unfasten the lower case: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    FixMat
    $36.95
    • Use a P5 pentalobe screwdriver to remove the four 6.4 mm‑long screws securing the lower case.
  3. Display and Camera Cables Disconnection, Insert an opening pick: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Display and Camera Cables Disconnection, Insert an opening pick: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Display and Camera Cables Disconnection, Insert an opening pick: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Apply a suction handle to the center of the lower case's front edge.
    • Pull up on the suction handle to create a gap between the lower case and the frame.
    • Insert an opening pick into the gap.
  4. Display and Camera Cables Disconnection, Release the snapping clips: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Display and Camera Cables Disconnection, Release the snapping clips: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Display and Camera Cables Disconnection, Release the snapping clips: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • During the next two steps you'll feel and hear six snapping clips release. If a clip doesn't release, insert your opening pick farther and try again.
    • Slide the pick to the bottom right corner to release the first clip.
    • Slide the pick around the corner and up the right edge to release the next two clips.
  5. Display and Camera Cables Disconnection: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Display and Camera Cables Disconnection: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Display and Camera Cables Disconnection: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the opening pick in the original gap created with the suction handle.
    • Slide the opening pick to the bottom left corner and up the left edge to release the three remaining snapping clips.
  6. Display and Camera Cables Disconnection, Release the sliding tabs: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Display and Camera Cables Disconnection, Release the sliding tabs: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Display and Camera Cables Disconnection, Release the sliding tabs: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Four sliding tabs along the back edge of the MacBook firmly secure the lower case. Separating these tabs requires a lot of force—consider using gloves to protect your hands from the sharp edges of the lower case.
    • Keep the lower case flat to the frame and firmly slide it straight away from the back edge, one corner at a time, to disengage the sliding tabs.
    • Don't pull up until the cover is completely separated.
  7. Display and Camera Cables Disconnection, Remove the lower case: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Display and Camera Cables Disconnection, Remove the lower case: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Display and Camera Cables Disconnection, Remove the lower case: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the lower case.
    • During reassembly:
    • Set the lower case in place and align the sliding tabs with the screw heads they slide over. Press down and slide the lower case toward the back edge to engage the tabs—it'll stop sliding as the tabs engage.
    • When one side is engaged, it may push the other out of alignment. Check both sides as you push, there should be no gap along the back edge.
    • Once the lower case is flush with the frame, press down firmly along the perimeter to engage the six snapping clips.
    • You'll hear and feel a distinct click as each clip snaps into place.
  8. Display and Camera Cables Disconnection, Remove the battery connector cover tape: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Display and Camera Cables Disconnection, Remove the battery connector cover tape: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Display and Camera Cables Disconnection, Remove the battery connector cover tape: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use blunt nose tweezers or your fingers to remove the piece of tape covering the battery connector cover.
    • During reassembly, use the leftover adhesive to secure the tape to the cover.
  9. Display and Camera Cables Disconnection, Remove the battery connector cover: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Display and Camera Cables Disconnection, Remove the battery connector cover: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Display and Camera Cables Disconnection, Remove the battery connector cover: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a 3IP Torx Plus screwdriver to remove the two 1.5 mm‑long screws securing the battery connector cover.
    • Remove the cover.
  10. Display and Camera Cables Disconnection, Disconnect the battery: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Display and Camera Cables Disconnection, Disconnect the battery: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use an opening pick to pry up and disconnect the battery connector.
    • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It might take a few tries to align the connector.
  11. Display and Camera Cables Disconnection, Unfasten the speaker cable and hinge covers: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Display and Camera Cables Disconnection, Unfasten the speaker cable and hinge covers: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The right speaker will be on your left-hand side when working on the MacBook, as it's laying upside down.
    • Use a 3IP Torx Plus screwdriver to remove the following screws:
    • Two 2.6 mm‑long screws securing the left hinge cover
    • Two 1.5 mm‑long screws securing the speaker cable cover
  12. Display and Camera Cables Disconnection, Remove the covers: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the speaker cable cover.
  13. Display and Camera Cables Disconnection: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Display and Camera Cables Disconnection: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Display and Camera Cables Disconnection: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the point of a spudger into one of the left hinge cover's screw holes.
    • Push the hinge cover away from the back edge to dislodge it.
    • Remove the hinge cover.
  14. Display and Camera Cables Disconnection, Disconnect the right speaker: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Display and Camera Cables Disconnection, Disconnect the right speaker: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Display and Camera Cables Disconnection, Disconnect the right speaker: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to pry up and disconnect the right speaker press connector.
  15. Display and Camera Cables Disconnection, Unfasten the right speaker: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Display and Camera Cables Disconnection, Unfasten the right speaker: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three screws securing the right speaker:
    • One 5.5 mm‑long 4IP Torx Plus screw
    • One 2.7 mm‑long 4IP Torx Plus screw
    • One 3.5 mm‑long 6IP Torx Plus screw
  16. Display and Camera Cables Disconnection, Remove the right speaker: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Display and Camera Cables Disconnection, Remove the right speaker: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Display and Camera Cables Disconnection, Remove the right speaker: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure the cable on the top right edge of the speaker doesn't get caught on the logic board, as it may tear.
    • Lift the speaker's left edge over the frame and slide it to the left to remove it.
    • During reassembly, slide the speaker cable under the left edge of the antenna bar assembly before laying the speaker in its recess.
  17. Display and Camera Cables Disconnection, Unfasten the speaker cable and hinge covers: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Display and Camera Cables Disconnection, Unfasten the speaker cable and hinge covers: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The left speaker will be on your right-hand side when working on the MacBook, as it's laying upside down.
    • Two 2.6 mm‑long screws securing the right hinge cover
  18. Display and Camera Cables Disconnection, Remove the covers: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  19. Display and Camera Cables Disconnection, Remove the right hinge cover: crwdns2935265:019crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Display and Camera Cables Disconnection, Remove the right hinge cover: crwdns2935265:019crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Display and Camera Cables Disconnection, Remove the right hinge cover: crwdns2935265:019crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the point of a spudger into one of the right hinge cover's screw holes.
  20. Display and Camera Cables Disconnection, Disconnect the left speaker: crwdns2935265:020crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Display and Camera Cables Disconnection, Disconnect the left speaker: crwdns2935265:020crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Display and Camera Cables Disconnection, Disconnect the left speaker: crwdns2935265:020crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to pry up and disconnect the left speaker press connector.
  21. Display and Camera Cables Disconnection, Unfasten the left speaker: crwdns2935265:021crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Display and Camera Cables Disconnection, Unfasten the left speaker: crwdns2935265:021crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  22. Display and Camera Cables Disconnection, Remove the left speaker: crwdns2935265:022crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Display and Camera Cables Disconnection, Remove the left speaker: crwdns2935265:022crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Display and Camera Cables Disconnection, Remove the left speaker: crwdns2935265:022crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure the cable on the top left edge of the speaker doesn't get caught on the logic board, as it may tear.
    • Lift the speaker's right edge over the frame and slide it to the right to remove it.
    • During reassembly, slide the speaker cable under the right edge of the antenna bar assembly before laying the speaker in its recess.
  23. Display and Camera Cables Disconnection, Remove the antenna cables cover: crwdns2935265:023crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Display and Camera Cables Disconnection, Remove the antenna cables cover: crwdns2935265:023crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Display and Camera Cables Disconnection, Remove the antenna cables cover: crwdns2935265:023crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a 3IP Torx Plus screwdriver to remove the two 1.5 mm‑long screws securing the antenna cables cover.
    • Remove the cover.
  24. Display and Camera Cables Disconnection, Disconnect the antenna bar: crwdns2935265:024crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Display and Camera Cables Disconnection, Disconnect the antenna bar: crwdns2935265:024crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Display and Camera Cables Disconnection, Disconnect the antenna bar: crwdns2935265:024crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    $3.99
    • Insert one arm of a pair of angled tweezers under the metal neck of one of the antenna connectors and lift straight up to disconnect it.
    • Disconnect the other antenna.
    • To reconnect antenna connectors, hold each one in place over its socket and press down with the flat end of your spudger. The connector will snap into place.
  25. Display and Camera Cables Disconnection, Unfasten the antenna bar: crwdns2935265:025crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Display and Camera Cables Disconnection, Unfasten the antenna bar: crwdns2935265:025crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 4IP Torx Plus screwdriver to remove the two 5.5 mm‑long screws securing the antenna bar.
  26. Display and Camera Cables Disconnection, Remove the antenna bar: crwdns2935265:026crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Display and Camera Cables Disconnection, Remove the antenna bar: crwdns2935265:026crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the antenna bar.
  27. Display and Camera Cables Disconnection, Remove the foam pad: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Display and Camera Cables Disconnection, Remove the foam pad: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Tesa 61395 Tape
    $2.99
    • A foam pad hides two screws securing the display and camera cables cover. It's secured with light adhesive.
    • Use tweezers or your fingers to remove the foam pad from the cover.
    • During reassembly, use the leftover adhesive to secure the pad. If the pad doesn't stick, use double-sided tape to secure it.
  28. Display and Camera Cables Disconnection, Unfasten the cables cover: crwdns2935265:028crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Display and Camera Cables Disconnection, Unfasten the cables cover: crwdns2935265:028crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Display and Camera Cables Disconnection, Unfasten the cables cover: crwdns2935265:028crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a 3IP Torx Plus screwdriver to remove the four 1.5 mm‑long screws securing the display and camera cables cover.
    • Remove the cover.
  29. Display and Camera Cables Disconnection, Disconnect the display and camera: crwdns2935265:029crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Display and Camera Cables Disconnection, Disconnect the display and camera: crwdns2935265:029crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Display and Camera Cables Disconnection, Disconnect the display and camera: crwdns2935265:029crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry up and disconnect the display and camera cable press connectors.
  30. Display and Camera Cables Disconnection, Reassembly information: crwdns2935265:030crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Display and Camera Cables Disconnection, Reassembly information: crwdns2935265:030crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Display and Camera Cables Disconnection, Reassembly information: crwdns2935265:030crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • During reassembly, use the flat end of a spudger to gently push the display and camera cables under the logic board.
  31. Display and Camera Cables Disconnection, Unfasten the display and camera cables: crwdns2935265:031crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Display and Camera Cables Disconnection, Unfasten the display and camera cables: crwdns2935265:031crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a 3IP Torx Plus screwdriver to remove the two 2.8 mm‑long screws securing the display and camera cables to the frame.
Spencer Day
crwdns2935283:009/14/22crwdne2935283:0
122,002 crwdns2915208:0crwdne2915208:0
crwdns2935297:0857crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:022,116crwdne2935297:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 46
