Dispenser Disconnection (Prereq)
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Dispenser Disconnection (Prereq), Safety Precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dispenser Disconnection (Prereq), Safety Precautions: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin your repair, perform the following:
    • Turn off the main water supply
    • Unplug your washer
    • Disconnect all water connections at the rear of your washer
  2. Dispenser Disconnection (Prereq), Unfasten the top panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dispenser Disconnection (Prereq), Unfasten the top panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dispenser Disconnection (Prereq), Unfasten the top panel: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips driver to remove the two bottom 16.5 mm-long screws securing the top panel brackets.
  3. Dispenser Disconnection (Prereq), Remove the top panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dispenser Disconnection (Prereq), Remove the top panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the top panel 1-2 inches towards the rear of the device to disconnect its clips.
  4. Dispenser Disconnection (Prereq): crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dispenser Disconnection (Prereq): crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Tilt the top panel upward to completely disconnect it from the chassis.
    • Remove the top panel.
  5. Dispenser Disconnection (Prereq), Remove the detergent drawer: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dispenser Disconnection (Prereq), Remove the detergent drawer: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the detergent drawer away from the chassis as far as it will go.
  6. Dispenser Disconnection (Prereq): crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dispenser Disconnection (Prereq): crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dispenser Disconnection (Prereq): crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press down on the "Push" button to disengage the clips securing the detergent drawer.
    • Pull the drawer out of its slot on the chassis and remove it.
  7. Dispenser Disconnection (Prereq), Disconnect the control panel: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dispenser Disconnection (Prereq), Disconnect the control panel: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dispenser Disconnection (Prereq), Disconnect the control panel: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the three harness connectors for the control panel.
    • Always grip cables by their connectors and not the wires themselves.
  8. Dispenser Disconnection (Prereq), Unclip the control panel cable: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dispenser Disconnection (Prereq), Unclip the control panel cable: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your hands to unclip the control panel cable from the detergent dispenser.
  9. Dispenser Disconnection (Prereq), Unclip the control panel cable: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dispenser Disconnection (Prereq), Unclip the control panel cable: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dispenser Disconnection (Prereq), Unclip the control panel cable: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a flathead screwdriver between the chassis and the plastic clip securing the control panel cable.
    • Compress the clip and slide it out of the chassis to remove it.
    • Move the cables out of the way of the detergent dispenser hoses before you continue.
  10. Dispenser Disconnection (Prereq), Detergent dispenser hose information: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To prevent confusion, label each hose and its corresponding dispenser connection.
    • You can use masking tape or mark the components themselves.
  11. Dispenser Disconnection (Prereq): crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dispenser Disconnection (Prereq): crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use slip joint pliers to pinch the detergent dispenser hose clamp and pull it away from the assembly.
  12. Dispenser Disconnection (Prereq): crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dispenser Disconnection (Prereq): crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use slip joint pliers to gently rotate the detergent dispenser hose back and forth around its connection and loosen it.
  13. Dispenser Disconnection (Prereq): crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Dispenser Disconnection (Prereq): crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the detergent dispenser hose straight off its connection on the assembly.
    • Repeat the loosening and removal procedure for each hose.
  14. Dispenser Disconnection (Prereq), Disconnect the dispenser: crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Dispenser Disconnection (Prereq), Disconnect the dispenser: crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Dispenser Disconnection (Prereq), Disconnect the dispenser: crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips driver to loosen the screw securing the bellows to the detergent dispenser.
    • Pull the bellows straight off its connection on the dispenser to disconnect it.
Bill Gilbert
crwdns2935283:006/30/22crwdne2935283:0
37,786 crwdns2915208:0crwdne2915208:0
crwdns2935297:0261crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,514crwdne2935297:0
crwdns2942667:0crwdne2942667:0 62
