To remove the brew assembly, the device must first be opened.
Remove all attachments, such as the water reservoir, coffee grounds drawer, and bean compartment lid.
Remove all coffee beans.
Pry the central ventilation cover up.
Use the spudger to press in on both sides of the marked area. Then the front cover around the on / off switch is unlocked. You can then lift it up at the front and pull it out at an angle.
If the side openings for the spudger cannot be found, the model is slightly different. With this version you have to insert the spudger into the gap between the front panel and cover, about 3 cm from the edge and then push it firmly towards the center to unlock. At the same time, lift the cover a little at the front.
Flip up the front cover.
Remove the cover. In the model with the side holes, you can pull them out at an angle to the front. With the other model, you have to push it back a little to unhook it, then lift it up.
Unscrew the two T15 Torx screws that secure the side panels at the top.
The lock is located under the Jura badge on the back. Turn it counterclockwise about 20 degrees, then you can remove it.
Unfortunately, this one is very stuck. Nothing helped with this device, no suction cup or stiff adhesive tape. Here it is opened with a somewhat more rustic method:
Two small holes were drilled a few millimeters deep, then two small screws were screwed in. The badge could finally be turned and removed with a pair of pliers.
This is what it looks like underneath. The lock is secured with an oval head screw. It looks like a rivet. To open you need a special oval head bit, in an emergency you can use pliers.
Remove the oval head screw.
Push the lock firmly upwards as far as possible.
The notches must be lifted out of the openings. They are located on both sides at the top and bottom about 1.5 cm from the edge and 7 cm from the front edge.
This is what the wedge-shaped notches look like
Lay the machine on its side.
Pry the side panel about 7 cm from the front edge, about 3 mm high. This will cause the catch to come out of its opening. Use a strong tool, preferably one made of plastic.
Position of the wedge-shaped notch: 7 cm from the front edge, 1.5 cm from the top or bottom edge.
Leave the tool in place. Insert an opening pick 7 cm from the front edge so that the wedge-shaped notch can no longer engage in its opening. Pull out the tool.
In the same way, insert another opening pick on the opposite edge.
Push the side panel firmly backwards. It may get stuck a bit and you need to use a plastic pry tool to help.
Take off the side panel and set it aside.
Repeat for the other side panel.
Release the catches on the top of the inner cover.
Flip the inner cover down and lift it out. The brew group becomes now visible.
The third picture shows a view of the other side.
Peel off the silicone tube with a pair of tweezers.
Unscrew the Torx T20 machine screw in the middle on the left.
Unscrew the Torx T20 machine screw in the middle on the right.
Unscrew the Torx T15 screw at the bottom right.
The brew assembly is now free. Gently tip it out at the bottom and remove it from the device.
Give the author +30 points!
crwdns2934873:0crwdne2934873:0
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Toll erklärt! Ich könnte die gesamte Brüheinheit damit zerlegen, reinigen und reparieren. Meine Jura ist jetzt wieder wie neu. 😀
