Dishwasher Water Inlet Valve Replacement
    • In order to gain access to the water valve, the bottom panel must be removed
    • The bottom panel is held on with either two or four screws, depending on the model.
    • Remove the screws, and remove the panel.
    • In order to check the solenoid coil on the water valve, remove the wire leads that connect to the solenoid coil from the wire harness
    • These are slide-on terminal connectors attached to the ends of the wire—just pull them off.
    • Using the ohmmeter, set the range on R × 1000, and place the probes on the solenoid coil terminals
    • The meter should read between 700- and 900-ohms resistance. If not, replace the water valve.
    • If this screen is filled with debris, it must be cleaned out
    • Be careful not to distort the screen.
    • Use a small flat-blade screwdriver and pry out the screen. Then wash out the screen, making sure that all of the debris is removed
    • Reinstall the screen.
    • Before removing the water valve, turn off the water supply to the dishwasher.
    • Disconnect the water supply line from the inlet end of the water valve and remove the fill hose from the outlet side
    • Remove the screws that hold the water valve to the chassis of the dishwasher
    • To install the new water valve, just reverse the disassembly procedure and reassemble.
    • Check for water leaks. If none are found, reinstall the bottom panel and restore the electricity to the dishwasher.
Matt Zieminski
crwdns2935283:002/23/15crwdne2935283:0
46,371 crwdns2915208:0crwdne2915208:0
crwdns2935297:028crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:021,871crwdne2935297:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 58
crwdns2942667:0crwdne2942667:0 714
