Dishwasher stopped washing. No pump sound. Display goes from Active to Clean in about 1 minute.
Cause: pump impeller blocked. .
Take out water with a cup or turkey baster and sponge.
Take out filter: left turn the cylindrical filter, take out the silver flat filter, drain water with sponge or turkey baster. Then remove white plastic part front/right by pulling out the long latch horizontally with pliers and then pull the plastic up.
That gives access to the impeller. Make sure it is not blocked. In my case there was a broken piece of glass that blocked it. Make sure it turns freely.. Replace everything - should work now.
