Disc Brake Shimano BR-M445 Brake Pads Replacement
  1. Disc Brake Shimano BR-M445 Brake Pads Replacement, Brake pads: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disc Brake Shimano BR-M445 Brake Pads Replacement, Brake pads: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the hub dynamo connector
  2. Disc Brake Shimano BR-M445 Brake Pads Replacement, Remove the front wheel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disc Brake Shimano BR-M445 Brake Pads Replacement, Remove the front wheel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Loosen the clamping screw with 4mm Allen key / Allen and remove the front wheel from the fork.
  3. Disc Brake Shimano BR-M445 Brake Pads Replacement, Pull out the cotter pin: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disc Brake Shimano BR-M445 Brake Pads Replacement, Pull out the cotter pin: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disc Brake Shimano BR-M445 Brake Pads Replacement, Pull out the cotter pin: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press the cotter pin together with the pointed pliers at the ends and pull out.
  4. Disc Brake Shimano BR-M445 Brake Pads Replacement, Remove brake pads: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disc Brake Shimano BR-M445 Brake Pads Replacement, Remove brake pads: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disc Brake Shimano BR-M445 Brake Pads Replacement, Remove brake pads: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the squeaky brake pads out with the needle nose pliers. (For heavily worn brake pads, push the brake pistons outwards).
  5. Disc Brake Shimano BR-M445 Brake Pads Replacement, Insert new brake pads: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disc Brake Shimano BR-M445 Brake Pads Replacement, Insert new brake pads: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the new brake pads together with the spring into the caliper.
  6. Disc Brake Shimano BR-M445 Brake Pads Replacement, Insert safety pin: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disc Brake Shimano BR-M445 Brake Pads Replacement, Insert safety pin: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disc Brake Shimano BR-M445 Brake Pads Replacement, Insert safety pin: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the new split pin and gently press the ends apart with the needle nose pliers.
  7. Disc Brake Shimano BR-M445 Brake Pads Replacement, Install front wheel: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disc Brake Shimano BR-M445 Brake Pads Replacement, Install front wheel: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disc Brake Shimano BR-M445 Brake Pads Replacement, Install front wheel: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the front wheel into the fork and tighten the axle bolt with the 4mm Allen key / Allen key.
    • Test concentricity and dynamo.
Repeat the steps in order to reassemble your device.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934883:0irlandacrwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Froebel Christian
crwdns2935283:002/02/16crwdne2935283:0
447 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 54
crwdns2942667:0crwdne2942667:0 4,811
