Disassembling the Nokia 6300
crwdns2942287:0crwdne2942287:0Disassembling the Nokia 6300 is not very hard and if you know how to disassemble other Nokia phones this will be very easy. You need a Torx T6 screwdriver.
Take off the back cover by pushing it down and sliding it backwards.
Take out the battery, SIM card, and MicroSD card.
Unscrew the two T6 Torx screws.
Try to seperate the front cover from the rest of the phone. The front cover is held by four plastic clips.
You can take off the keypad now, this is sitting loose on top of the sensors.
Unscrew the four remaining T6 Torx screws.
The motherboard with it's screen are now loose, you can pop it right out.
If you've been using this phone for a while, there's probably some dust inside the back shell.
There's a lot of contacts exposed, so make sure not to damage those.
crwdns2935229:020crwdne2935229:0
in this where is bluetooth module plzz give me ans @ bhatia.abhi98@gmail.com
