Disassembling the HP Pavilion tx2500 Bezel
  1. Disassembling the HP Pavilion tx2500 Bezel, Screen Rotator: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Completely turn off and unplug device. Lay the device bottom side up on a soft surface.
  2. Disassembling the HP Pavilion tx2500 Bezel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling the HP Pavilion tx2500 Bezel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Squeeze the latches on the battery until you hear a click. Slide out the battery.
  3. Disassembling the HP Pavilion tx2500 Bezel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #0 screwdriver, remove the 4.5 mm screw from the WLAN model screen.
    • Once unscrewed, lift the right side of the WLAN module compartment cover and swing it to the left.
  4. Disassembling the HP Pavilion tx2500 Bezel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the plastic opening tool, disconnect the WLAN antenna cables from the WLAN module.
  5. Disassembling the HP Pavilion tx2500 Bezel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #0 screwdriver, unscrew the 4.5 mm screw from the middle section in the battery compartment.
  6. Disassembling the HP Pavilion tx2500 Bezel: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to disconnect the wires in the upper corners.
  7. Disassembling the HP Pavilion tx2500 Bezel: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the laptop front side up and then use your fingers to lift up the keyboard.
  8. Disassembling the HP Pavilion tx2500 Bezel: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up the black latch that connects the film strip to the base of the computer.
    • Use the plastic opening tool to disconnect the film strip from the base of the computer.
  9. Disassembling the HP Pavilion tx2500 Bezel: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling the HP Pavilion tx2500 Bezel: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the screen 90 degrees and remove the base under the screen.
  10. Disassembling the HP Pavilion tx2500 Bezel: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rotate the screen back towards you.
    • Lift up the convertible hinge to unclip it from the base of the computer.
  11. Disassembling the HP Pavilion tx2500 Bezel: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling the HP Pavilion tx2500 Bezel: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the Phillips #0 screwdriver, remove both of the 5.0 mm screws on the base of the rotator.
  12. Disassembling the HP Pavilion tx2500 Bezel: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift up and remove the screen.
  13. Disassembling the HP Pavilion tx2500 Bezel, Bezel: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling the HP Pavilion tx2500 Bezel, Bezel: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling the HP Pavilion tx2500 Bezel, Bezel: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the wire from the system board using the plastic opening tool.
    • Disconnect the wire from the optical drive using the plastic opening tool.
    • Gently lift the top cover from the tablet.
  14. Disassembling the HP Pavilion tx2500 Bezel: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling the HP Pavilion tx2500 Bezel: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic opening tool, disconnect the plastic blue film from the tablet.
    • Disconnect the wire using the plastic opening tool.
  15. Disassembling the HP Pavilion tx2500 Bezel: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling the HP Pavilion tx2500 Bezel: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the system board from the tablet.
    • Turn the system board over and lay it flat on a soft surface.
  16. Disassembling the HP Pavilion tx2500 Bezel: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the bezel from the system board.
Sarah Naiser
crwdns2935283:010/13/15crwdne2935283:0
324 crwdns2915208:0crwdne2915208:0
Sam Houston State, Team 1-4, Blackburne Fall 2015 crwdns2935289:0Sam Houston State, Team 1-4, Blackburne Fall 2015crwdne2935289:0
SHSU-BLACKBURNE-F15S1G4
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 782
