Disassembling the Garmin eTrex Vista-H Outer Case
  1. Disassembling the Garmin eTrex Vista-H Outer Case, Removing Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the device to the backside, and locate the metal tab at the center of the back cover.
  2. Disassembling the Garmin eTrex Vista-H Outer Case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the metal tab up, and rotate it counterclockwise. This will unlock the back case cover.
  3. Disassembling the Garmin eTrex Vista-H Outer Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling the Garmin eTrex Vista-H Outer Case: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the battery plate off to either insert or remove 2 AA batteries.
  4. Disassembling the Garmin eTrex Vista-H Outer Case, Disassembling the Garmin eTrex Vista-H Outer Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling the Garmin eTrex Vista-H Outer Case, Disassembling the Garmin eTrex Vista-H Outer Case: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the wedge side of a spudger (or a small, flat head screwdriver), remove the black rubber case support from the device body.
  5. Disassembling the Garmin eTrex Vista-H Outer Case: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling the Garmin eTrex Vista-H Outer Case: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling the Garmin eTrex Vista-H Outer Case: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With the pick side of a spudger (or tweezers), peel the sticky tape from the device.
  6. Disassembling the Garmin eTrex Vista-H Outer Case: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Split the front and rear panels by inserting a small pointed tool (such as a pen point or a screwdriver tip SL1.5) in the 5 plastic tabs along the sides of the device.
    • Do not remove the back panels quickly. If too much force is applied, there is a wire connection that will break.
    • CAUTION! Be careful not to force the tabs inward. This will result in broken tabs.
  7. Disassembling the Garmin eTrex Vista-H Outer Case: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling the Garmin eTrex Vista-H Outer Case: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With tweezers (or your fingernails), carefully disconnect the wires between the PC input and the motherboard.
Ryan Green
crwdns2935283:010/17/10crwdne2935283:0
93 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 21-30, Regan Fall 2010 crwdns2935289:0Cal Poly, Team 21-30, Regan Fall 2010crwdne2935289:0
CPSU-REGAN-F10S21G30
crwdns2942667:0crwdne2942667:0 5,246
