Disassembling of Wahl Lithium Ion Trimmer
  1. Disassembling of Wahl Lithium Ion Trimmer, Disassembling of Wahl Lithium Ion Trimmer: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling of Wahl Lithium Ion Trimmer, Disassembling of Wahl Lithium Ion Trimmer: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Begin by removing the rubber grip along the handle.
    How do you take rubber piece off handle
    Billy Joe Furr - crwdns2934203:0crwdne2934203:0
    It appears the friction of your skin against the rubber grip can pull it down from the top enough that you can see how to peel it off.
    Matt Benson -
    How do you remove the rubber grip??
    octavia197424 - crwdns2934203:0crwdne2934203:0
    Pardon the analogy,
    … but it's on there a little bit like a condom.
    Start at the Top of the trimmer.
    Use your fingernail to pry back the lip of the rubber.
    Then start rolling it down the handle.
    Toward the end you may just have to brute force - shove it off.
    Mark Wingerd - crwdns2934203:0crwdne2934203:0
    Check the model number. Mine looks exactly like the one pictured here.
    Again, my trimmer model 9854L has the battery soldered in place. So, unless you have a soldering gun and tools, or want to buy one and do this job, don’t bother with the rest of the steps here as this is required for battery replacement.
    Janek Kuchmistrz - crwdns2934203:0crwdne2934203:0
    You might want to disassemble it to oil the motor. Mine required oiling after a few years
    Mike Smith - crwdns2934203:0crwdne2934203:0
  2. Disassembling of Wahl Lithium Ion Trimmer: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws from the top to take the metal piece and plastic part off.
  3. Disassembling of Wahl Lithium Ion Trimmer: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling of Wahl Lithium Ion Trimmer: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry open the plastic cover into two separate pieces. The plastic is very durable so don't worry about breaking it upon prying it open.
    it doesn’t show any detail like the spring location
    kglenhunter - crwdns2934203:0crwdne2934203:0
    Be careful- mine popped open suddenly and all interior parts fell out! Also, as mentioned above, be cautious to not push against the silver metal motor axle while opening- use the white plastic to the side as a spot.
crwdns2935229:012crwdne2935229:0
nathan
crwdns2935283:010/22/13crwdne2935283:0
1.440 crwdns2915208:0crwdne2915208:0
University of Maryland, Team 1-3, Shastany Fall 2013 crwdns2935289:0University of Maryland, Team 1-3, Shastany Fall 2013crwdne2935289:0
UMD-SHASTANY-F13S1G3
crwdns2947412:05crwdne2947412:0
Well this does not show how to properly remove the metal piece that surrounds the power button , which needs to be removed to access 2 screws ( that I can see it) that need to be removed to completely separate the plastic encasement of the intrrnals has
Andrew Beeson - crwdns2934203:0crwdne2934203:0
very helpful for the first two steps. I need like six more between the 2nd step and the last step. but otherwise, very helpful.  Thank you so much
tundraorchid - crwdns2934203:0crwdne2934203:0
You open the clipper by using small flat head on the 4 tabs on the handle
JOSH - crwdns2934203:0crwdne2934203:0
When attempting to clean the unit, I removed the razor heads and everything fell out that I wasn't holding. How do I get them back and in what positions?
Patrick Serle - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 112
crwdns2942667:0crwdne2942667:0 45,386
