Disassembling VTech MobiGo Touch Learning System Keyboard
  1. Disassembling VTech MobiGo Touch Learning System Keyboard, Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery covers and the four batteries.
  2. Disassembling VTech MobiGo Touch Learning System Keyboard: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling VTech MobiGo Touch Learning System Keyboard: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
    • Remove the eight 6.0 mm JIS #0 case screws.
  3. Disassembling VTech MobiGo Touch Learning System Keyboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling VTech MobiGo Touch Learning System Keyboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a plastic opening tool, separate the two pieces of the case carefully.
  4. Disassembling VTech MobiGo Touch Learning System Keyboard, Disassembling VTech MobiGo Touch Learning System Keyboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling VTech MobiGo Touch Learning System Keyboard, Disassembling VTech MobiGo Touch Learning System Keyboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the six 6.5 mm Philips J0 screws that are connected to the circuit board.
    • Use light pressure to prevent damage to the circuit board.
  5. Disassembling VTech MobiGo Touch Learning System Keyboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 9.0 mm Philips J0 screw from the blue plastic cover.
    • Once the screw is removed, remove the blue plastic cover.
  6. Disassembling VTech MobiGo Touch Learning System Keyboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling VTech MobiGo Touch Learning System Keyboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 4.0 mm Philips J0 screws located on the orange case.
    • Use gentle force to prevent stripping of screws.
  7. Disassembling VTech MobiGo Touch Learning System Keyboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling VTech MobiGo Touch Learning System Keyboard: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling VTech MobiGo Touch Learning System Keyboard: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two "L" shaped brackets located on both sides of the device.
    • Use the magnetic mat to store these brackets.
  8. Disassembling VTech MobiGo Touch Learning System Keyboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the spring that was connected to the "L" shaped bracket and slowly remove it.
  9. Disassembling VTech MobiGo Touch Learning System Keyboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling VTech MobiGo Touch Learning System Keyboard: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the circuit board from the case using a plastic opening tool.
    • Make sure to use a plastic opening tool for this step.
  10. Disassembling VTech MobiGo Touch Learning System Keyboard: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 3.5 mm Philips J0 screw located underneath the circuit board.
    • Keep the circuit board out of the way to avoid damaging it.
  11. Disassembling VTech MobiGo Touch Learning System Keyboard: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slowly remove the keyboard panel.
    • Use a spudger if necessary.
    • The keys will fall out once the keyboard panel is removed.
    • Remove all of the keys and set them aside with the keyboard panel.
  12. Disassembling VTech MobiGo Touch Learning System Keyboard: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently remove the keyboard circuit board with a plastic opening tool.
    Where do you get a replacement circuit board?
    Kara - crwdns2934203:0crwdne2934203:0
RBansil
crwdns2935283:008/27/15crwdne2935283:0
221 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 8-3, Eyestone Fall 2015 crwdns2935289:0USF Tampa, Team 8-3, Eyestone Fall 2015crwdne2935289:0
USFT-EYESTONE-F15S8G3
crwdns2935297:017crwdne2935297:0
Was gifted a mobigo2 for my niece but it came without keyboard .. I was curious if you knew where I might find a replacement keyboard?
ROXXY - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,989
