Disassembling VTech MobiGo Touch Learning System Keyboard
crwdns2869540:0crwdne2869540:0: 2,7 B
3
22
110
2.674
crwdns2955950:0crwdne2955950:0: 2
crwdns2960002:01crwdne2960002:0, crwdns2960006:01crwdne2960006:0
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2959986:0crwdne2959986:0: 2
crwdns2959982:02crwdne2959982:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:020crwdne2931287:0
This is a step by step guide to show how to replace the keyboard. Prior to this guide, you will need to refer to the Disassembling guide for the case.
    1. Disassembling VTech MobiGo Touch Learning System Keyboard, Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the battery covers and the four batteries.
    2. Disassembling VTech MobiGo Touch Learning System Keyboard: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling VTech MobiGo Touch Learning System Keyboard: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
      • Remove the eight 6.0 mm JIS #0 case screws.
    3. Disassembling VTech MobiGo Touch Learning System Keyboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling VTech MobiGo Touch Learning System Keyboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using a plastic opening tool, separate the two pieces of the case carefully.
    1. Disassembling VTech MobiGo Touch Learning System Keyboard, Disassembling VTech MobiGo Touch Learning System Keyboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling VTech MobiGo Touch Learning System Keyboard, Disassembling VTech MobiGo Touch Learning System Keyboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the six 6.5 mm Philips J0 screws that are connected to the circuit board.
      • Use light pressure to prevent damage to the circuit board.
    2. Disassembling VTech MobiGo Touch Learning System Keyboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 9.0 mm Philips J0 screw from the blue plastic cover.
      • Once the screw is removed, remove the blue plastic cover.
    3. Disassembling VTech MobiGo Touch Learning System Keyboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling VTech MobiGo Touch Learning System Keyboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the two 4.0 mm Philips J0 screws located on the orange case.
      • Use gentle force to prevent stripping of screws.
    4. Disassembling VTech MobiGo Touch Learning System Keyboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling VTech MobiGo Touch Learning System Keyboard: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling VTech MobiGo Touch Learning System Keyboard: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the two "L" shaped brackets located on both sides of the device.
      • Use the magnetic mat to store these brackets.
    5. Disassembling VTech MobiGo Touch Learning System Keyboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the spring that was connected to the "L" shaped bracket and slowly remove it.
    6. Disassembling VTech MobiGo Touch Learning System Keyboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling VTech MobiGo Touch Learning System Keyboard: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Gently lift the circuit board from the case using a plastic opening tool.
      • Make sure to use a plastic opening tool for this step.
    7. Disassembling VTech MobiGo Touch Learning System Keyboard: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 3.5 mm Philips J0 screw located underneath the circuit board.
      • Keep the circuit board out of the way to avoid damaging it.
    8. Disassembling VTech MobiGo Touch Learning System Keyboard: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slowly remove the keyboard panel.
      • Use a spudger if necessary.
      • The keys will fall out once the keyboard panel is removed.
      • Remove all of the keys and set them aside with the keyboard panel.
    9. Disassembling VTech MobiGo Touch Learning System Keyboard: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently remove the keyboard circuit board with a plastic opening tool.
RBansil
crwdns2935283:008/27/15crwdne2935283:0
221 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 8-3, Eyestone Fall 2015 crwdns2935289:0USF Tampa, Team 8-3, Eyestone Fall 2015crwdne2935289:0
USFT-EYESTONE-F15S8G3
Was gifted a mobigo2 for my niece but it came without keyboard .. I was curious if you knew where I might find a replacement keyboard?
ROXXY - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 110
crwdns2959996:0crwdne2959996:0 2,674
