Disassembling TDK Life on Record bottom panel
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Disassembling TDK Life on Record bottom panel, Disassembling TDK Life on Record bottom panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four rubber feet of the device using a metal spudger.
  2. Disassembling TDK Life on Record bottom panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling TDK Life on Record bottom panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 9 mm Phillips #0 screws located under the feet of the device.
    • Remove the four 9 mm Torx #8 screws located on each side of the bottom the device.
  3. Disassembling TDK Life on Record bottom panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling TDK Life on Record bottom panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the bottom cover of the device towards you.
  4. Disassembling TDK Life on Record bottom panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling TDK Life on Record bottom panel: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 13 mm Phillips #1 screws.
  5. Disassembling TDK Life on Record bottom panel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling TDK Life on Record bottom panel: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use one hand to grip the device from the side of the handle, and use the other hand to grip the side of the device that contains the woofer
    • The woofer is the circular component located at the bottom of the device after the bottom cover has been removed
    • Pull apart the compartments by applying force in opposite directions.
    • Do not pull with extreme force!! There are many electrical wires inside the device that can become damaged if the bottom panel is removed without care
  6. Disassembling TDK Life on Record bottom panel: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the seven cables attached to the motherboard.
    • Do not use too much force when pulling on the wires. Pulling with too much force can damage the wires.
Eduardo Barrios
crwdns2935283:009/14/15crwdne2935283:0
341 crwdns2915208:0crwdne2915208:0
CSU Fullerton, Team 1-2, Bruce Fall 2015 crwdns2935289:0CSU Fullerton, Team 1-2, Bruce Fall 2015crwdne2935289:0
CSUF-BRUCE-F15S1G2
crwdns2936753:07crwdne2936753:0 18
crwdns2942667:0crwdne2942667:0 66
