Disassembling Sony CPF-IP001 Main Speaker Housing Disassembly
  1. Disassembling Sony CPF-IP001 Main Speaker Housing Disassembly, Main Speaker Housing Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two 6mm Phillips #0 screws.
    • Remove two 7.5 mm Phillips #0 screws.
    • Remove seven 4 mm Phillips #0 screws.
  2. Disassembling Sony CPF-IP001 Main Speaker Housing Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Sony CPF-IP001 Main Speaker Housing Disassembly: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Sony CPF-IP001 Main Speaker Housing Disassembly: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove six 4 mm Phillips #0 screws from the metal backing.
    • Remove six 5 mm Phillips #0 screws from the metal backing.
    • Using the plastic opening tool, remove the metal plate from the main speaker by gently pulling on it.
  3. Disassembling Sony CPF-IP001 Main Speaker Housing Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Sony CPF-IP001 Main Speaker Housing Disassembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the plastic dock cover by using two fingers to push the attached metal piece forward and slide it out of the holes.
  4. Disassembling Sony CPF-IP001 Main Speaker Housing Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Sony CPF-IP001 Main Speaker Housing Disassembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Sony CPF-IP001 Main Speaker Housing Disassembly: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the plastic opening tool, detach the wires connected to the metal plate
    • When disconnecting the wires, be careful not to pull on the wires themselves. Use the plastic opening tool and the connector to disconnect it.
    • Use the plastic opening tool to remove wires connected to the circuit board on the far right.
    • Use the tweezers to remove wires connected to the circuit board in between the two black wires.
    • Use the tweezers to press the release tab on the front and back of the plastic white wire head.
    • Once the tab is pressed on both sides, lift up to slide wire head out of socket.
  5. Disassembling Sony CPF-IP001 Main Speaker Housing Disassembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two 5 mm Phillips #0 screws.
  6. Disassembling Sony CPF-IP001 Main Speaker Housing Disassembly: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Sony CPF-IP001 Main Speaker Housing Disassembly: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Sony CPF-IP001 Main Speaker Housing Disassembly: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the metal spudger, loosen the metal cap at the end of the speaker.
    • Slide down the loosened cap to remove it from the end of the speaker.
    • Simultaneously push down on the buttons and slide the speaker out from the casing.
Marlena Perez
crwdns2935283:004/14/15crwdne2935283:0
442 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-14, Maness Spring 2015 crwdns2935289:0Cal Poly, Team 6-14, Maness Spring 2015crwdne2935289:0
CPSU-MANESS-S15S6G14
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 883
