Disassembling Sanyo SCP-8100 Back Panel
  1. Disassembling Sanyo SCP-8100 Back Panel, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Sanyo SCP-8100 Back Panel, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Sanyo SCP-8100 Back Panel, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push and hold the button on the back toward the direction of the arrow to unlock the battery.
    • Lift and remove the battery from the back of the phone.
  2. Disassembling Sanyo SCP-8100 Back Panel, Back Panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Sanyo SCP-8100 Back Panel, Back Panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a push pin, pull out the plug on the back, located under the antenna.
    • You may try to use a spudger or opening tool, however, you may damage the plug because those tools are too thick.
  3. Disassembling Sanyo SCP-8100 Back Panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the four 6mm long screws with a Tri-Wing Y1 screwdriver.
  4. Disassembling Sanyo SCP-8100 Back Panel: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Sanyo SCP-8100 Back Panel: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to pry the back panel along the edges.
    • You may need to apply some force when prying.
  5. Disassembling Sanyo SCP-8100 Back Panel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Sanyo SCP-8100 Back Panel: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Sanyo SCP-8100 Back Panel: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • While removing the back panel, take out the rubber cover on each side.
Yemane
crwdns2935283:004/13/13crwdne2935283:0
11 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 10-41, Amido Spring 2013 crwdns2935289:0Cal Poly, Team 10-41, Amido Spring 2013crwdne2935289:0
CPSU-AMIDO-S13S10G41
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 469
