Push and hold the button on the back toward the direction of the arrow to unlock the battery.
Lift and remove the battery from the back of the phone.
Using a push pin, pull out the plug on the back, located under the antenna.
Unscrew the four 6mm long screws with a Tri-Wing Y1 screwdriver.
Use a plastic opening tool to pry the back panel along the edges.
While removing the back panel, take out the rubber cover on each side.
