Disassembling Sanyo Katana Eclipse X Outer Casing
  1. Disassembling Sanyo Katana Eclipse X Outer Casing, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Sanyo Katana Eclipse X Outer Casing, Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press the battery release button located on the back of the phone.
    • With the button depressed, pull down on the battery protector to remove it from the phone.
    • The phone's battery will now be exposed.
  2. Disassembling Sanyo Katana Eclipse X Outer Casing: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide a thin object under the white tab located on the bottom of the battery and carefully lift away from the phone.
    • A small, flat-tip screwdriver or credit card may be helpful for this step.
    • The battery should now be free of the phone.
  3. Disassembling Sanyo Katana Eclipse X Outer Casing, Casing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This task can be difficult. This phone has several specialized screws that are engineered to prevent removal.
    • With the battery removed, four (5.75mm) screws that hold the outer case together are visible (circled in picture).
  4. Disassembling Sanyo Katana Eclipse X Outer Casing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your "Damaged Screw Remover", remove the screws from their current positions.
    • Once the screws are removed, the phone can be split apart.
    • You may need to wiggle the case a bit in order to get it loose
    • The case is now open.
Scott Kelley
crwdns2935283:011/10/11crwdne2935283:0
University of Maine, Team 1-3, Diaz Fall 2012 crwdns2935289:0University of Maine, Team 1-3, Diaz Fall 2012crwdne2935289:0
UMAINE-DIAZ-F12S1G3
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 546
