crwdns2937539:0crwdnd2937539:0crwdne2937539:0
Toasters are categorized as heating appliances. Their function is to develop sufficient heat to heat and toast a slice of bread. Breakfast certainly wouldn't be the same without the toasters.
To inspect, repair or replace any internal parts, including the heating elements, you will need to disassemble the toaster.
Here is a complete guide with a detailed description, steps and pictures to facilitate you on how to disassemble the Rival 16131 Toaster Shell.
Turn the toaster over and remove the rubber bumper feet.
Use a Phillips head screwdriver to remove all four 12 mm screws that are attached to the toaster shell.
With the dial facing you, push the toaster base up and away until the base is just over the lip of the shell. This will disconnect the browning dial from the rest of the toaster.
Reach into the shell and grab the back white part of the lever.
Hold the grey lever with both your index finger and middle finger. Next, pull it.
Next, remove the shell.
crwdns2935229:09crwdne2935229:0
