Disassembling Razer Basilisk X Hyperspeed Top Case
    • First heat up the underside of the device, so the glue of the stickers softens up.
  1. Disassembling Razer Basilisk X Hyperspeed Top Case, Remove Stickers: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Razer Basilisk X Hyperspeed Top Case, Remove Stickers: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Razer Basilisk X Hyperspeed Top Case, Remove Stickers: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the tweezers to lift the bottom slider, if you use your nails you might just lift the slider, instead of all the glue with the slider.
  2. Disassembling Razer Basilisk X Hyperspeed Top Case, Unscrew: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove all 4 screws.
    • There is 1 at the bottom under the slider.
    • The top ones are under the letter A from BASILISK and the other one between the EE from HYPERSPEED.
    • The last one is on top of the last 4 digits of the IFETEL number.
  3. Disassembling Razer Basilisk X Hyperspeed Top Case, Remove the Top: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Razer Basilisk X Hyperspeed Top Case, Remove the Top: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • First remove battery, after that, lift it from the bottom using your nail or a prying tool from the gap at the bottom. Open it carefully, since there are wire connectors. Carefully disconnect from the plastic to avoid damage, DO NOT PULL FROM THE WIRES.
  4. Disassembling Razer Basilisk X Hyperspeed Top Case, Admire your work: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If you need to remove the board, you need a 00 Philips bit for the screws on the board and a 1 Philips bit for the screws on the side buttons, other than that, you have full access to the board.
Toaster Roaster
crwdns2935283:004/14/23crwdne2935283:0
324 crwdns2915208:0crwdne2915208:0
crwdns2936751:024crwdne2936751:0 14
crwdns2936753:07crwdne2936753:0 67
crwdns2936753:030crwdne2936753:0 278
crwdns2942667:0crwdne2942667:0 4,053
