Disassembling Qingping Air Monitor Lite CGDN1
  1. Disassembling Qingping Air Monitor Lite CGDN1, Remove screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Qingping Air Monitor Lite CGDN1, Remove screen: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Qingping Air Monitor Lite CGDN1, Remove screen: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • When removing the screen with the suction handle and a jimmy be very careful at the right side of the screen and don't damage the connection like I did (see red circle).
    • Carefully remove the screen towards the front. The screen is glued with some tape (see the orange marker).
    • Maybe use some heat to soften the clue.
    • I used a combination of a suction pad and Jimmy.
  2. Disassembling Qingping Air Monitor Lite CGDN1, Remove screen backing plane: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • 2 Philips screws are holding the backing plane of the screen
  3. Disassembling Qingping Air Monitor Lite CGDN1, Disconnect screen: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Qingping Air Monitor Lite CGDN1, Disconnect screen: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Qingping Air Monitor Lite CGDN1, Disconnect screen: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the small black ledge to remove the flat cable of the screen. Orange circle
  4. Disassembling Qingping Air Monitor Lite CGDN1, Remove main PCB: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Qingping Air Monitor Lite CGDN1, Remove main PCB: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the flat cable of the touch sensor by lifting the little black ledge, see the orange circle.
    • One screw holding the PCB, green circle
  5. Disassembling Qingping Air Monitor Lite CGDN1, Open the back: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Qingping Air Monitor Lite CGDN1, Open the back: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • 4 Philips screws hold the back in place.
    • You'll need a very long/narrow bit to reach these screws!
  6. Disassembling Qingping Air Monitor Lite CGDN1, Remove sensors & battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You can slide the complete inner parts to the front.
  7. Disassembling Qingping Air Monitor Lite CGDN1, Dismanteling the PM sensor: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Qingping Air Monitor Lite CGDN1, Dismanteling the PM sensor: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Qingping Air Monitor Lite CGDN1, Dismanteling the PM sensor: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Sensor is held by the 10 pin connector
    • Don't let the springs jump away
    • By slightly bending the cover you can lift the cover from the sensor housing
    • 5 little philips screw hold the sesnor PCB in place. To access the fan connector you have to remove the pcb
rkuijer
crwdns2935283:006/09/15crwdne2935283:0
226 crwdns2915208:0crwdne2915208:0
Thank you for the guide! The part number for a replacement sensor appears to be PMS7003. There are some minor cosmetic differences but it appears to function correctly. I would suggest conducting a calibration routine / making sure the sensor is exposed to exterior air a few times over the next few days.
ironeagl - crwdns2934203:0crwdne2934203:0
Do you know whether the Air Monitor works when removing the battery? My air monitor is constantly running hot (temperature shown is ~3 Degrees higher than room temperature and I suspect a bad battery to be the culprit. It also only holds a charge for few minutes after disconnecting from power. I'd like to remove it for peace of mind and also to be able to use the temperature sensor again.
Stokel - crwdns2934203:0crwdne2934203:0
Yes it works with disconnected battery.
Georgy Aleksanenkov -
crwdns2936753:030crwdne2936753:0 105
crwdns2942667:0crwdne2942667:0 2,385
