Disassembling Polaroid a520 Lens
  1. Disassembling Polaroid a520 Lens, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Polaroid a520 Lens, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place your thumb on the battery cover and push left towards the arrow.
    • The cover will release and pop open.
  2. Disassembling Polaroid a520 Lens: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the batteries from the camera.
  3. Disassembling Polaroid a520 Lens, Casing: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove four 3 mm screws on the right side of the camera using a Phillips #1 screwdriver.
    • This will release the front and back casings.
  4. Disassembling Polaroid a520 Lens: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
    • Repeat this step for the back casing.
  5. Disassembling Polaroid a520 Lens, LCD Screen: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Under the screen, locate the black plastic strip that sits above the white plastic strip.
  6. Disassembling Polaroid a520 Lens: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull both sides of the black piece upward-about a mm.
    • The black plastic piece is not meant to come all the way off, just enough to release the screen.
    • Once the piece is lifted carefully slide the screen out of the slot.
  7. Disassembling Polaroid a520 Lens, Logic Board: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew and remove the four (6 mm) screws on the inside casing.
  8. Disassembling Polaroid a520 Lens: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the inner casing off of the camera.
  9. Disassembling Polaroid a520 Lens: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew and remove the four (4mm) screws from the logic board.
  10. Disassembling Polaroid a520 Lens: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to pry up all four sides of the logic board and slide it out of the camera.
  11. Disassembling Polaroid a520 Lens, Lens: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew and remove the two (5mm) screws from the logic board to the far left.
  12. Disassembling Polaroid a520 Lens: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the black plastic piece behind the lens.
  13. Disassembling Polaroid a520 Lens: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Similar to the LCD screen, pull the black piece up about a mm and it will release the lens.
    • The piece will not come all the way off; only enough to release the lens.
    • Once the black piece is lifted slide the ribbon out to release the lens.
Dani
crwdns2935283:006/24/10crwdne2935283:0
21 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-3, Johann Summer 2010 crwdns2935289:0Cal Poly, Team 3-3, Johann Summer 2010crwdne2935289:0
CPSU-JOHANN-R10S3G3
crwdns2942667:0crwdne2942667:0 1,219
