Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide)
crwdns2936621:0crwdne2936621:0
  1. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide), Case Separation: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide), Case Separation: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the front and rear cases.
  9. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide), Battery: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide), Battery: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the help of a spudger, gently pry off and remove the battery cable retainer on the back casing assembly.
    • The easiest access to the battery cable retainer is where the battery cable comes out.
    • You can also use the two small tabs on the side of the cable retainer. Locate the tabs and release one at a time. Be a little careful not to push the cover in and re-lock it.
  10. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #00 screwdriver, remove the two 5.0mm blue battery case screws.
    • Remove the plastic battery retaining bar.
  11. Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling PlayStation Vita Screen & Digitizer (Video Tutorial/Guide): crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using your finger or a spudger, lift the battery out and remove it.
    • Guide the battery wires through the hole in the back casing as you remove the battery.
djgodmandj
crwdns2935283:010/24/14crwdne2935283:0
284 crwdns2915208:0crwdne2915208:0
So is there any chance that this could be used as a modding possibility, where we could install a higher resolution /quality screen?
TheHeavy - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 175
crwdns2942667:0crwdne2942667:0 7,555
