Removing the frame will allow access to the eyes and solenoid should they need replacement.
Firmly grasp hold of the ring on the bottom of the 90 degree silver fitting on the front of the gun.
Pull hard, but slowly, on the macroline where it comes out of silver piece until it comes out.
Remove the regulator by unscrewing it in a clockwise direction.
Use the 5/64" hex key to remove the screw shown.
Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
Flip the marker over and use the 5/64" hex key to remove the screw shown.
Carefully remove the 9V battery and connector.
Remove the 9V battery from the connector.
Carefully disconnect the three connectors from the circuit board.
Use the 1/8" hex key to remove the two dome-headed screws by rotating them counter-clockwise.
Gently separate the top and bottom of the marker.
