Disassembling Palm Centro Logic Board
  1. Disassembling Palm Centro Logic Board, Disassembling Palm Centro Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Palm Centro Logic Board, Disassembling Palm Centro Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Press and slide open the battery cover.
  2. Disassembling Palm Centro Logic Board: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Caution: Turn cell phone off before removing battery!
    • Press battery to the right.
    • Then lift up battery pack to remove.
  3. Disassembling Palm Centro Logic Board: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Phone with battery removed
  4. Disassembling Palm Centro Logic Board, Back Housing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the touchpad pen from the top left corner on the back to reveal the last of 6 screws to be removed.
  5. Disassembling Palm Centro Logic Board: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the rubber cap at the top right to reveal the sixth screw.
    • Caution: There is a small Palm sticker under the rubber cap. Tampering with or removing this sticker will void your warranty!
    • Remove the six screws using the T5 Torx screwdriver.
  6. Disassembling Palm Centro Logic Board: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Palm Centro Logic Board: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the SIM card so housing can be separated.
  7. Disassembling Palm Centro Logic Board: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Palm Centro Logic Board: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic pry tool to separate the bottom of the case to remove the small plastic insert.
  8. Disassembling Palm Centro Logic Board: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Palm Centro Logic Board: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the small plastic insert at the bottom of the phone.
  9. Disassembling Palm Centro Logic Board: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Palm Centro Logic Board: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Continue with plastic pry tool all the way around the phone to remove the back housing.
  10. Disassembling Palm Centro Logic Board, Logic Board: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully peel back the tape holding the speaker (left) and keyboard (right) connection tabs in place.
  11. Disassembling Palm Centro Logic Board: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the plastic prying tool, lift the tabs and carefully pull the contact connections out on both sides.
    • Be very careful, these electronics are delicate!
  12. Disassembling Palm Centro Logic Board: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the logic board from the case by lifting and pulling out the bottom.
Chelsea Barackman
crwdns2935283:004/13/10crwdne2935283:0
42 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 15-49, Garner Spring 2010 crwdns2935289:0Cal Poly, Team 15-49, Garner Spring 2010crwdne2935289:0
CPSU-GARNER-S10S15G49
note: if you need to replace the logic board, follow this guide, insert a new board, and then follow the steps in reverse order to get a working phone.
Chelsea Barackman - crwdns2934203:0crwdne2934203:0
i try to on this mobile ..but cant do that, i try to on this mobile so many ways.. i want to whhy thi mobile not on and how to resolve it?
kelumaruna - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 3,224
