Disassembling Over-Ear Headphone Sennheiser HD4199
  1. Disassembling Over-Ear Headphone Sennheiser HD4199, Disassembling Over-Ear Headphone Sennheiser HD4199: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Over-Ear Headphone Sennheiser HD4199, Disassembling Over-Ear Headphone Sennheiser HD4199: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Over-Ear Headphone Sennheiser HD4199, Disassembling Over-Ear Headphone Sennheiser HD4199: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use two or three fingers slowly pull the cushion.
    • Caution: go gently and try not to apply too much force.
  2. Disassembling Over-Ear Headphone Sennheiser HD4199: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Over-Ear Headphone Sennheiser HD4199: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • By feel, locate 4 screws under the foam, 2 each side.
    • Scrap away just sufficient foam in order to be able to remove the screws, and remove them.
  3. Disassembling Over-Ear Headphone Sennheiser HD4199: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Over-Ear Headphone Sennheiser HD4199: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The speaker assembly is now held in the shell just be a number of tabs around the edges. Gently prise it out from these tabs and remove it.
    • Take care not to strain the wires.
    • On reassembly, make sure the headband fork is correctly positioned otherwise it will be impossible locate the speaker faceplate correctly in the shell.
    • Also on reassembly, make sure the speaker face plate is secured behind all the tabs.
  4. Disassembling Over-Ear Headphone Sennheiser HD4199: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Over-Ear Headphone Sennheiser HD4199: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • On the right side connection are made via a small printed circuit board. Remove 2 screws in order to remove this for re-soldering or replacement of any of the wires.
    • On replacing this circuit board, take care to ensure that it's both the right way round and the right way up
    • If you are replacing the main lead with the jack plug on the end, make sure that you have suitable strain relief to prevent the lead pulling on the soldered connections.
    • The wire colours are:
    • Right: Red
    • Left: Green
    • Common (Ground): Gold.
  5. Disassembling Over-Ear Headphone Sennheiser HD4199: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Over-Ear Headphone Sennheiser HD4199: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert wisdom here.
  6. Disassembling Over-Ear Headphone Sennheiser HD4199: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Over-Ear Headphone Sennheiser HD4199: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Over-Ear Headphone Sennheiser HD4199: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
Camera used : lumia 520
forevergoku
crwdns2935283:011/29/14crwdne2935283:0
307 crwdns2915208:0crwdne2915208:0
Hola Buenas, gracias por las fotos y la información. Te quiero hacer una consulta por si me puedes ayudar, quiero instalar un circuito de Bluetooth a los cascos, lo pondría entre el cable de salida del jack y el circuito verde? Supongo que el circuito sirve para unir los cables de ambos altavoces en una sola salida.
Muchas gracias de antemano
Marcos Riol González - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 11,594
