Disassembling Olympus Stylus Tough 6020 Prerequisite Guide
  1. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide and push the battery casing to open it.
    • Push the battery to eject it.
  2. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Bottom Plating: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Bottom Plating: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Bottom Plating: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the camera so that you are facing the bottom of the camera.
    • Using a Phillips 00 screwdriver, unscrew the three 3.9mm screws on the bottom of the camera.
    • Using a spudger, pry off the plating on the bottom of the camera.
  3. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Top Plating: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Top Plating: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Top Plating: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the camera so that you are facing the top of the camera.
    • Using a Phillips 00 screwdriver, unscrew the three 3.9mm screws located on the top of the camera.
    • Using a spudger, pry off the plating on the top of the camera.
  4. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Left Plating: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Left Plating: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the camera so the LCD is facing upwards.
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws located on the left side of the device.
  5. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Black "Olympus" Face Plate: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Black "Olympus" Face Plate: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Black "Olympus" Face Plate: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips 00 screwdriver, unscrew the 3.9mm screw located next to the black "Olympus" face plate.
    • Using a T6 Torx screwdriver, unscrew the two 3.5mm screws located on the black "Olympus" face plate.
    • Using a spudger, gently pry off the black "Olympus" face plate.
  6. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, End Casing: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, End Casing: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, End Casing: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws to the right of the cursor pad on the U-shaped frame.
    • Turn the device over so the front of the camera is facing you.
    • Using a Phillips 00 screwdriver, unscrew the two 3.9mm screws on the end casing.
    • Using a spudger, pry off the end casing.
  7. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Blue Face Plate: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Blue Face Plate: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Blue Face Plate: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the camera so the blue face plate is visible.
    • Using a Phillips 00 screwdriver, unscrew the two 3mm screws on the blue plate.
    • Using a Phillips 00 screwdriver, unscrew the 3.9mm screw located at the bottom of the camera straight down from the flash.
    • Using a spudger, gently pry off the blue face plate.
  8. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide, Back Plate: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips 00 screwdriver, unscrew the 9mm screws on the top of the camera to the right of the flash.
  9. Disassembling Olympus Stylus Tough 6020 Prerequisite Guide: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Olympus Stylus Tough 6020 Prerequisite Guide: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips 00 screwdriver, unscrew the wide 3.5mm screw located in the middle of the camera.
    • Using a Phillips 00 screwdriver, unscrew the 9mm screw located at the top left corner of the camera.
    • Using a spudger, separate the black plate from the camera.
Taylor Carabin
crwdns2935283:004/15/15crwdne2935283:0
259 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 2-6, Matresse Spring 2015 crwdns2935289:0Eastern Washington University, Team 2-6, Matresse Spring 2015crwdne2935289:0
EWU-MATRESSE-S15S2G6
crwdns2936753:030crwdne2936753:0 65
crwdns2942667:0crwdne2942667:0 1,053
