Disassembling Olympus Stylus 725 SW Back Panel
  1. Disassembling Olympus Stylus 725 SW Back Panel, Disassembling Olympus Stylus 725 SW Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Olympus Stylus 725 SW Back Panel, Disassembling Olympus Stylus 725 SW Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The battery is located on the bottom of the camera.
    • Remove the battery by placing your thumb on the bottom flap and sliding the release button away from the side the lens is on. (The screwdriver is simply used as a reference point, no screws need to be removed)
    • If the battery is dead, charge it for 60-90 minutes.
    • When installing a charged battery, align the battery appropriately. The positive signs and negative should line up.
  2. Disassembling Olympus Stylus 725 SW Back Panel, Disassembling Olympus Stylus 725 SW Back Panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Olympus Stylus 725 SW Back Panel, Disassembling Olympus Stylus 725 SW Back Panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Olympus Stylus 725 SW Back Panel, Disassembling Olympus Stylus 725 SW Back Panel: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 3 mm long cover screws at the corners of the camera using a Phillips #00 screwdriver.
    • Remove the 2 mm long screws securing the sides of the camera which holds the back panel using a Phillips #00 screwdriver.
  3. Disassembling Olympus Stylus 725 SW Back Panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Olympus Stylus 725 SW Back Panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be careful when removing the back cover; you will need to detach the connecting ribbons. Use tweezers if necessary.
    • Detach the ribbons using your thumb, sliding them out of their slots.
    • Set the back panel face up to keep the ribbons from touching anything.
Bobby Hodges
crwdns2935283:004/18/10crwdne2935283:0
49 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 33-71, Johann Spring 2010 crwdns2935289:0Cal Poly, Team 33-71, Johann Spring 2010crwdne2935289:0
CPSU-JOHANN-S10S33G71
crwdns2942667:0crwdne2942667:0 4,562
