Disassembling Olympus Stylus 1010 Case
  1. Disassembling Olympus Stylus 1010 Case, Disassembling Olympus Stylus 1010 Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Olympus Stylus 1010 Case, Disassembling Olympus Stylus 1010 Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the five Phillips #00 bottom and right side panel screws.
    Put a notice on here that the screws are very small and are easy to misplace while disassembling device. Also, while disassembling the device there was only one screw present, where the guide suggested there were three.
    Curtis Reedy - crwdns2934203:0crwdne2934203:0
    Before beginning, put a note that the camera should be turned off before proceeding.
    Add a note at the beginning of the guide that there are a large number of small screws that should be separated as the steps are completed.
    There's a capacitor .....watch out for it in every step.
    BILL BOYD - crwdns2934203:0crwdne2934203:0
  2. Disassembling Olympus Stylus 1010 Case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the right side panel by pulling off the large silver piece.
    There is no reference to removing screws from the right side panel, where it is necessary to remove 2 screws to do so.
  3. Disassembling Olympus Stylus 1010 Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Olympus Stylus 1010 Case: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the remaining three Phillips #00 side and front panel screws.
  4. Disassembling Olympus Stylus 1010 Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your thumb and forefinger, pull off the silver name plate and silver "T-shape" piece.
  5. Disassembling Olympus Stylus 1010 Case: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the black front panel by sliding it towards the lens and then pulling it up off of the camera.
  6. Disassembling Olympus Stylus 1010 Case: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Olympus Stylus 1010 Case: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Olympus Stylus 1010 Case: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three Phillips #00 screws from the front of the camera.
    • Using a spudger, lift the two tabs to separate the case—one tab on top and one tab on the right side.
    Wrong point of focus for the second picture. What should be in focus is very blurry.
  7. Disassembling Olympus Stylus 1010 Case: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Olympus Stylus 1010 Case: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Olympus Stylus 1010 Case: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a plastic spudger, lift up the black clips.
    • Still using the plastic spudger, detach the gold connector strip and white connector strip.
    • Using both hands, pull the camera apart into two pieces.
    There were multiple gold strips, so the one that needs to be pulled should be highlited in the picture.
    in step seven pull up the black bar of the ZIF connectors before pulling out the white or gold ribbons
Max McIntyre
crwdns2935283:001/21/11crwdne2935283:0
544 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-4, Forte Winter 2011 crwdns2935289:0Cal Poly, Team 13-4, Forte Winter 2011crwdne2935289:0
CPSU-FORTE-W11S13G4
crwdns2931471:06crwdne2931471:0
How did you get the ring around the lens off?? I can't seem to find that step and in all the pictures it's already off
Maureen - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 3,176
