Disassembling Novation Launchpad Mk2
    • Remove rubber mat on the bottom of the device using spudger or the tip of a screwdriver. Please remove the mat with care, do not use much force to prevent tears in the material. Optionally use the opening picks to make the mat not stick to the shell again.
    • Remove 7 screws under the rubber mat.
    • Separate the clips near handles of the launchpad shell using spudger or similar tool. Place the opening picks in the gaps of corners to ease the access to the clips. Do not apply much force to prevent breaking the clips.
    • Remove the bottom of the launchpad shell. Separate the launchpad into 4 layers. (Bottom case, PCB, rubber mat with button pads, top case)
To reassemble your device, follow these instructions in reverse order. Please note the glue on the rubber mat will dry up when left in the air for too long.
ComputerhullGaming
crwdns2935283:006/27/23crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 4
