This guide will show you how to remove the vibrator from the Nokia 3560.
Press down on the release latch on the bottom of the cover.
Once the latch is released, lift the cover from the phone.
Lift the front case off of the phone body.
The screen is held to the body by six screws.
Unscrew the six screws with a Torx screwdriver (six-pointed star shaped bit).
Insert a flat screwdriver between the black body and plastic layer.
Pry the layers apart. The LCD and plastic layer will lift out as one piece.
With the screws removed, the logic board can then be lifted out of the body by hand.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
The orange piece is the vibrator.
It is not fastened by any means.
Remove with tweezers.
