This guide show you how to access the phone's microphone, the component that receives sound when making a call.
Make sure your phone is turned off.
Press the button on the back of the phone and slide the back panel off.
Remove the battery by pulling it from the phone.
Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
Press the black tabs to release the front cover from the phone.
Remove the front cover from the phone.
Set the front cover, as indicated, aside.
Remove the screws as they are indicated in the order of the colors of the rainbow. (Red, Orange, Yellow, Green, Blue, Purple.)
Remove the screen assembly from the phone base.
Set the screen assembly aside.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use tweezers to remove the microphone from the phone's base.
