Disassembling Nokia 2366i Side Buttons
    1. Disassembling Nokia 2366i Side Buttons, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Nokia 2366i Side Buttons, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Turn off the phone.
      • Position the phone so that the back side is in view.
    2. Disassembling Nokia 2366i Side Buttons: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Apply pressure on the cover while simultaneously sliding the cover downward.
      • Remove the back battery cover.
    3. Disassembling Nokia 2366i Side Buttons: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Nokia 2366i Side Buttons: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Nokia 2366i Side Buttons: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert the spudger between the base of the phone and the phone battery.
      • Position the phone so that the battery won't fall out of the phone.
      • Carefully lift the battery out of the phone.
      • The battery lifts out of the phone easily.
    1. Disassembling Nokia 2366i Side Buttons, Rear Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Nokia 2366i Side Buttons, Rear Case: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a Phillips #00 screwdriver or your fingers to remove the rubber tabs at top back of the phone.
    2. Disassembling Nokia 2366i Side Buttons: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Nokia 2366i Side Buttons: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove four 5mm screws from the back of the phone using a T6 Torx screwdriver:
      • 2 screws at the bottom
      • 2 screws at the top
    3. Disassembling Nokia 2366i Side Buttons: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Nokia 2366i Side Buttons: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Rotate the phone clockwise so the edge is facing you.
      • Insert the spudger in tabs between the outer casing and the inside frame.
      • Slide the spudger upwards.
      • This will remove the rear case of the phone.
    4. Disassembling Nokia 2366i Side Buttons: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • The phone should now be in two different sections.
      • 1) The rear case of the phone.
      • 2) The motherboard and the rest of the phone.
    1. Disassembling Nokia 2366i Side Buttons, Motherboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Nokia 2366i Side Buttons, Motherboard: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the spudger to lift off the yellow clip near the top right corner of the motherboard.
    2. Disassembling Nokia 2366i Side Buttons: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Nokia 2366i Side Buttons: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Rotate the phone counterclockwise so that the edge is facing you.
      • Use the spudger to lift the motherboard out of the base of the phone.
      • Remove the motherboard from the base of the phone.
    1. Disassembling Nokia 2366i Side Buttons, Side Buttons: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Nokia 2366i Side Buttons, Side Buttons: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the spudger to pull off the top orange chip attached to the white tab.
    2. Disassembling Nokia 2366i Side Buttons: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Nokia 2366i Side Buttons: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Lightly pull up on the white tab to remove the orange tab from the logic board.
      • Don't worry about the glue on the bottom orange tab. It's only there to keep the side button in place.
Jonathan Newman
crwdns2935283:001/21/11crwdne2935283:0
516 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 1-14, Amido Winter 2011 crwdns2935289:0Cal Poly, Team 1-14, Amido Winter 2011crwdne2935289:0
CPSU-AMIDO-W11S1G14
crwdns2935297:096crwdne2935297:0
crwdns2942667:0crwdne2942667:0 1,150
