Disassembling Nokia 2366i Rear Case
  1. Disassembling Nokia 2366i Rear Case, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Nokia 2366i Rear Case, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn off the phone.
    • Position the phone so that the back side is in view.
  2. Disassembling Nokia 2366i Rear Case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply pressure on the cover while simultaneously sliding the cover downward.
    • Remove the back battery cover.
  3. Disassembling Nokia 2366i Rear Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Nokia 2366i Rear Case: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Nokia 2366i Rear Case: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the spudger between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • Carefully lift the battery out of the phone.
    • The battery lifts out of the phone easily.
  4. Disassembling Nokia 2366i Rear Case, Rear Case: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Nokia 2366i Rear Case, Rear Case: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #00 screwdriver or your fingers to remove the rubber tabs at top back of the phone.
  5. Disassembling Nokia 2366i Rear Case: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Nokia 2366i Rear Case: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove four 5mm screws from the back of the phone using a T6 Torx screwdriver:
    • 2 screws at the bottom
    • 2 screws at the top
  6. Disassembling Nokia 2366i Rear Case: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Nokia 2366i Rear Case: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the phone clockwise so the edge is facing you.
    • Insert the spudger in tabs between the outer casing and the inside frame.
    • Slide the spudger upwards.
    • This will remove the rear case of the phone.
  7. Disassembling Nokia 2366i Rear Case: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The phone should now be in two different sections.
    • 1) The rear case of the phone.
    • 2) The motherboard and the rest of the phone.
Jonathan Newman
crwdns2935283:001/21/11crwdne2935283:0
495 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 1-14, Amido Winter 2011 crwdns2935289:0Cal Poly, Team 1-14, Amido Winter 2011crwdne2935289:0
CPSU-AMIDO-W11S1G14
crwdns2935297:017crwdne2935297:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 1,589
