Disassembling Nokia 2366i Front Display
    1. Disassembling Nokia 2366i Front Display, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Nokia 2366i Front Display, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Turn off the phone.
      • Position the phone so that the back side is in view.
    2. Disassembling Nokia 2366i Front Display: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Apply pressure on the cover while simultaneously sliding the cover downward.
      • Remove the back battery cover.
    3. Disassembling Nokia 2366i Front Display: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Nokia 2366i Front Display: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Nokia 2366i Front Display: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Insert the spudger between the base of the phone and the phone battery.
      • Position the phone so that the battery won't fall out of the phone.
      • Carefully lift the battery out of the phone.
      • The battery lifts out of the phone easily.
    1. Disassembling Nokia 2366i Front Display, Front Cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Keep the phone closed.
      • Hold the phones sideways with the front cover of the phone facing up.
    2. Disassembling Nokia 2366i Front Display: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Nokia 2366i Front Display: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Find the slight crease on the side that divides the display assembly in half.
      • Slowly wedge the spudger into the crease.
      • It's a little difficult to perform this step because the crease is narrow. Do not rush because you may damage the phone
    3. Disassembling Nokia 2366i Front Display: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Nokia 2366i Front Display: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Run the spudger all along the crease while lifting up.
      • Separate the front cover from the front base.
    1. Disassembling Nokia 2366i Front Display, Main Display: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Nokia 2366i Front Display, Main Display: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the four 5mm screws on the metal casing using the T6 Torx screwdriver.
    2. Disassembling Nokia 2366i Front Display: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Nokia 2366i Front Display: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using the spudger, disconnect the green display cable.
    3. Disassembling Nokia 2366i Front Display: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Nokia 2366i Front Display: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Nokia 2366i Front Display: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Lift the metal casing.
      • Be careful not to pull the casing too hard because it is still attached to the phone by a wire.
      • Remove the main display from under the metal casing.
    1. Disassembling Nokia 2366i Front Display, Front Display: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Nokia 2366i Front Display, Front Display: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Nokia 2366i Front Display, Front Display: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Fold the metal casing back over.
      • Disconnect the orange front display data cable with the spudger.
      • Hold the phone so that the antenna is facing towards you.
      • Lift up and flip over the metal casing.
    2. Disassembling Nokia 2366i Front Display: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using your fingers, remove the front display.
Michael Machado
crwdns2935283:001/21/11crwdne2935283:0
337 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 1-14, Amido Winter 2011 crwdns2935289:0Cal Poly, Team 1-14, Amido Winter 2011crwdne2935289:0
CPSU-AMIDO-W11S1G14
crwdns2935297:096crwdne2935297:0
crwdns2936753:030crwdne2936753:0 42
crwdns2942667:0crwdne2942667:0 1,366
