Disassembling Nikon SB-400 Flash
  1. Disassembling Nikon SB-400 Flash, Remove Batteries: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Nikon SB-400 Flash, Remove Batteries: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Always remove hazardous energy from the things on which you are doing work.
    • Remove the SB-400 flash from the camera if able.
    • Remember in my case that the flash is unable to be removed from the camera, so remove batteries from both.
    • The SB-400 uses two AA batteries.
  2. Disassembling Nikon SB-400 Flash, Remove Screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Nikon SB-400 Flash, Remove Screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two screws from the bottom of the flash.
    • Remove the two screws from under the battery cover.
  3. Disassembling Nikon SB-400 Flash, Remove Top Cover: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Nikon SB-400 Flash, Remove Top Cover: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Nikon SB-400 Flash, Remove Top Cover: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger around the split near the battery cover to remove the top cover.
  4. Disassembling Nikon SB-400 Flash, Discharge Capacitor: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • WARNING: RISK OF ELECTRIC SHOCK FROM ENERGY STORED IN CAPACITORS.
    • If you are not confortable discharging a capacitor, it is recommend to bring the unit to a professional for repair.
    • As you can see, a flash capacitor is very large and the risk of shock must be addressed. I discharged it using a screw driver with a plastic handle.
    • The capacitor may be 330V.
  5. Disassembling Nikon SB-400 Flash, Disconnect Ribbon Wires: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Nikon SB-400 Flash, Disconnect Ribbon Wires: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Nikon SB-400 Flash, Disconnect Ribbon Wires: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the plastic clips on the connectors and pull the ribbon wires out.
    • The ribbons are delicate. Take care not to tear them.
  6. Disassembling Nikon SB-400 Flash, Remove PCB Screws: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Nikon SB-400 Flash, Remove PCB Screws: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Nikon SB-400 Flash, Remove PCB Screws: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two screws holding down the PCB.
    • Move the PCB out of the way to expose the battery case. The wires should remain attached.
  7. Disassembling Nikon SB-400 Flash, Remove Battery Case: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Nikon SB-400 Flash, Remove Battery Case: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Nikon SB-400 Flash, Remove Battery Case: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the battery case by sliding out the middle spacer and set it aside.
    • Leverage the battery case up and forward to remove.
    • Move the battery case out of the way, the wires should remain attached.
  8. Disassembling Nikon SB-400 Flash, Remove Lock Plate: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Nikon SB-400 Flash, Remove Lock Plate: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Nikon SB-400 Flash, Remove Lock Plate: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the small silver screw holding the ribbon wires in place.
    • Remove the four screws that hold the lock plate in place.
    • There are two small springs and several small plastic pieces that must be placed in specific orientation to ensure proper locking operation. It is recommended to take photos as you remove the plate.
    • With the four screws removed, the hot shoe (metal plate in contact with the camera) will drop off the flash.
  9. Disassembling Nikon SB-400 Flash, Avoid Damaging Wires on Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Nikon SB-400 Flash, Avoid Damaging Wires on Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The reassembly is the reverse of the disassembly.
    • Ensure these two fastener holes are clear when the top cover in installed to avoid damaging wires.
Andrew Greco
crwdns2935283:006/03/19crwdne2935283:0
229 crwdns2915208:0crwdne2915208:0
Thanks for this guide! I had a battery in my second hand SB-400 that had leaked. I have successfully removed it in part thanks to this guide. Now let’s hope the thing still works, just have to get some batteries to test it.
Rebelder - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 82
crwdns2942667:0crwdne2942667:0 1,312
