Disassembling Nerf Vortex Vigilon Inner Mechanism
crwdns2862623:0crwdne2862623:0
crwdns2942641:0crwdne2942641:0
  1. Disassembling Nerf Vortex Vigilon Inner Mechanism, Removing the inner mechanism's screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the seven #00 1 cm Phillips screws that attach the inner mechanism to the back cover.
    • Remove the #00 1.2 cm Phillips screw located to the right of the white casing.
  2. Disassembling Nerf Vortex Vigilon Inner Mechanism, Removing the front cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Nerf Vortex Vigilon Inner Mechanism, Removing the front cover: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Nerf Vortex Vigilon Inner Mechanism, Removing the front cover: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • An orange block will likely fall out as you remove the front cover. The clip and spring will fall out as well, if they have not already.
    • Wiggle the front cover out from under the white piece and lift up from the gun.
    • Pulling the cover off is tricky due to its inner fitting.
    • Be sure to replace the orange block, spring, and clip before this step in reassembly.
  3. Disassembling Nerf Vortex Vigilon Inner Mechanism, Removing the inner mechanism: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The spring, cap, and rotating lever will likely fall out as you remove the inner mechanism.
    • Disconnect the inner mechanism from the outer cover by lifting the inner mechanism towards you.
    • Be sure to replace the spring, cap, and rotating lever before this step in reassembly.
Cara Pew
crwdns2935283:009/29/14crwdne2935283:0
911 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-6, Forte Fall 2014 crwdns2935289:0Cal Poly, Team 13-6, Forte Fall 2014crwdne2935289:0
CPSU-FORTE-F14S13G6
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 74
