Disassembling Nerf Recon CS-6 Shell
  1. Disassembling Nerf Recon CS-6 Shell, Remove Magazine: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Skip this step if magazine is already removed.
    • Pull slide back.
    • Pull backwards on release buttons and slide magazine out.
    • Push slide back forward and pull trigger.
    My priming bar is stuck how do I fix this?
    Ethan - crwdns2934203:0crwdne2934203:0
  2. Disassembling Nerf Recon CS-6 Shell, Remove Visible Screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Phillips #0 Screwdriver to remove these 9 screws.
    • All screws marked in red are 9.6 mm Phillips #0 screws.
    • Note that left most screw is longer than the rest and is a 18.6 mm Phillips #0 screw.
  3. Disassembling Nerf Recon CS-6 Shell, Remove Hidden Screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Nerf Recon CS-6 Shell, Remove Hidden Screws: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull slide back to reveal more screws.
    • Remove these 2 screws.
    • Push slide forward.
    • Pull trigger to release compression of the main spring.
    • Screws are 9.6 mm Phillips #0.
    • Pulling the trigger will keep spring from launching out of the gun when the two halves are separated.
    Lost the trigger spring. What spec of spring can I replace it with?
    derekpearcy - crwdns2934203:0crwdne2934203:0
  4. Disassembling Nerf Recon CS-6 Shell, Remove Plunger Cap: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws on the plunger cap.
    • Tug the plunger cap off.
  5. Disassembling Nerf Recon CS-6 Shell, Remove Slide Screws: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 2 screws on the slide.
    • Hold the two halves of the gun together to prevent any springs from launching out.
  6. Disassembling Nerf Recon CS-6 Shell, Split the Gun in Half: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling Nerf Recon CS-6 Shell, Split the Gun in Half: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the gun apart at the middle seam.
    • Watch for any springs that might launch out.
    Pay attention to the orientation of the tabs on the compression tube. The tabs fit into grooves on the side of the gun. This tripped me up.
    Bob - crwdns2934203:0crwdne2934203:0
crwdns2935229:012crwdne2935229:0
Asad Qureshi
crwdns2935283:010/22/14crwdne2935283:0
595 crwdns2915208:0crwdne2915208:0
Baylor, Team 8-14, Williams Fall 2014 crwdns2935289:0Baylor, Team 8-14, Williams Fall 2014crwdne2935289:0
BU-WILLIAMS-F14S8G14
Does anyone have a spare spring for this gun I am missing mine
The Lazy Gamer - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 12,313
