Disassembling NEC LCD1770NX Monitor Enclosure
  1. Disassembling NEC LCD1770NX Monitor Enclosure, Stand: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling NEC LCD1770NX Monitor Enclosure, Stand: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the monitor face down on a clean, flat surface.
  2. Disassembling NEC LCD1770NX Monitor Enclosure: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling NEC LCD1770NX Monitor Enclosure: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Firmly remove the back panel of the stand by pulling it up and away from the monitor.
  3. Disassembling NEC LCD1770NX Monitor Enclosure: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling NEC LCD1770NX Monitor Enclosure: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the two 6mm Phillips PH2 screws to detach the stand enclosure from the stand.
  4. Disassembling NEC LCD1770NX Monitor Enclosure: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling NEC LCD1770NX Monitor Enclosure: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Firmly grasp the stand enclosure with your hand and slide it to base of stand.
  5. Disassembling NEC LCD1770NX Monitor Enclosure: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the two 14.5mm Phillips PH2 screws holding the stand to the monitor.
  6. Disassembling NEC LCD1770NX Monitor Enclosure: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling NEC LCD1770NX Monitor Enclosure: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the the stand straight up to remove it.
  7. Disassembling NEC LCD1770NX Monitor Enclosure, Monitor Enclosure: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling NEC LCD1770NX Monitor Enclosure, Monitor Enclosure: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling NEC LCD1770NX Monitor Enclosure, Monitor Enclosure: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the monitor screen face up.
    • Pull the frame off by placing your fingers on the inside of the frame and pulling out and up, the frame should snap off.
    • Continue your way around the screen.
  8. Disassembling NEC LCD1770NX Monitor Enclosure: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling NEC LCD1770NX Monitor Enclosure: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling NEC LCD1770NX Monitor Enclosure: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the two 7mm screws from the bottom of the button assembly.
    • Do not pull the button assembly out too quickly or with too much force! Damage to the wires can occur.
    • Pull the button assembly out a few inches and unplug the colored cables.
  9. Disassembling NEC LCD1770NX Monitor Enclosure: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling NEC LCD1770NX Monitor Enclosure: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the gold colored 7mm Phillips PH000 screw holding the button assembly to the monitor.
    • Remove the button assembly from the monitor.
  10. Disassembling NEC LCD1770NX Monitor Enclosure: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the monitor face-down, unscrew the 5 7mm Phillips PH2 screws around the outside of the enclosure.
  11. Disassembling NEC LCD1770NX Monitor Enclosure: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling NEC LCD1770NX Monitor Enclosure: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling NEC LCD1770NX Monitor Enclosure: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the 2 14.5mm Phillips PH2 screws located on the raised center of the enclosure.
    • Carefully pull the enclosure off the monitor.
  12. Disassembling NEC LCD1770NX Monitor Enclosure: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling NEC LCD1770NX Monitor Enclosure: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the 10 5mm Philips PH2 screws holding the metal casing to the monitor.
  13. Disassembling NEC LCD1770NX Monitor Enclosure: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling NEC LCD1770NX Monitor Enclosure: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the the metal casing off of the monitor to reveal the motherboards.
    I have a similar monitor and the power switch is broken. I need to get inside and try to fix it
    Thank you
    Richard Morgan - crwdns2934203:0crwdne2934203:0
John Patterson
crwdns2935283:010/19/13crwdne2935283:0
271 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 11-36, Amido Fall 2013 crwdns2935289:0Cal Poly, Team 11-36, Amido Fall 2013crwdne2935289:0
CPSU-AMIDO-F13S11G36
crwdns2942667:0crwdne2942667:0 6,025
