Disassembling ModRetro M64 Pro Controller
crwdns2869540:0crwdne2869540:0: 1,2 тыс.
4
47
180
1 153
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2955944:0crwdne2955944:0: 10 - 15 crwdns2931279:0crwdne2931279:0
crwdns2944444:0crwdne2944444:0
crwdns2944446:0crwdne2944446:0
This is a step by step disassembly of the ModRetro M64 Pro Controller. Use this guide when modifying or replacing components on the controller.
    1. Disassembling ModRetro M64 Pro Controller, Battery Pack: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling ModRetro M64 Pro Controller, Battery Pack: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Slide the battery release button down.
      • Pull the battery pack away from the controller and set it aside.
    2. Disassembling ModRetro M64 Pro Controller, Front Panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling ModRetro M64 Pro Controller, Front Panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling ModRetro M64 Pro Controller, Front Panel: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Place the device on a soft, flat surface to avoid scratching the top shell.
      • On the back of the controller, remove eleven screws on the back using the Tri-wing Y1 Screwdriver.
      • The eleven screws come in four distinct lengths. Organize them carefully during removal. The exact placement for each group of screws is highlighted in the image.
      • Gently separate the front panel from the back panel and set them aside.
    3. Disassembling ModRetro M64 Pro Controller, Membranes and Buttons: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling ModRetro M64 Pro Controller, Membranes and Buttons: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling ModRetro M64 Pro Controller, Membranes and Buttons: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Gently pull three membranes from their pockets to expose the buttons and D pad.
      • Remove the buttons and the D-pad from the shell with tweezers or by hand. If you flip the shell over, they will fall out freely.
      • For reassembly, align the guide tabs on the buttons and rubber membranes to ensure proper orientation during reassembly.
    4. Disassembling ModRetro M64 Pro Controller, Thumb Stick Gate: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling ModRetro M64 Pro Controller, Thumb Stick Gate: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • To remove the thumb stick gate, remove three screws using a Tri-wing Y1 Screwdriver.
      • Pull the Gate away from the front panel and set aside.
    5. Disassembling ModRetro M64 Pro Controller, Rumble Motor: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling ModRetro M64 Pro Controller, Rumble Motor: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling ModRetro M64 Pro Controller, Rumble Motor: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • To prevent damaging the board, use ESD protection
      • Unplug the Rumble Motor cable connector from the PCB.
      • Remove one screw holding down the motor using the Y1 Tri-wing screwdriver.
      • Lift the motor away and set aside.
    6. Disassembling ModRetro M64 Pro Controller, Battery PCB: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling ModRetro M64 Pro Controller, Battery PCB: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling ModRetro M64 Pro Controller, Battery PCB: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Unscrew four screws using a Tri-wing Y1 Screwdriver.
      • The upper battery PCB connects to the underlying main PCB via a board-to-board connector located near the bottom-left corner of the battery PCB (Image 2).
      • Gently wiggle the battery PCB to loosen up the connector before lifting the PCB vertically. Set them aside.
    7. Disassembling ModRetro M64 Pro Controller, Back Enclosure: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling ModRetro M64 Pro Controller, Back Enclosure: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling ModRetro M64 Pro Controller, Back Enclosure: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Unscrew three screws around the joystick using a Tri-wing Y1 Screwdriver.
      • Grip the top of the battery compartment. Gently wiggle while pulling straight up to clear the two metal alignment pins and release the back enclosure.
      • You will experience some physical resistance here.
      • Separate the back enclosure from the PCB and battery compartment module, then set the enclosure aside.
    8. Disassembling ModRetro M64 Pro Controller, Battery Compartment: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling ModRetro M64 Pro Controller, Battery Compartment: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Disconnect two off-white connectors on each side. Use your fingers or tweezers to disconnect the connector.
      • Separate the PCB from the Battery Compartment and set aside.
    9. Disassembling ModRetro M64 Pro Controller, L/R Bumper Membrane: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Disassembling ModRetro M64 Pro Controller, L/R Bumper Membrane: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Slide the button membrane and bumper PCB on each side away from the battery compartment, then set them aside.
    10. Disassembling ModRetro M64 Pro Controller, Thumb Stick: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling ModRetro M64 Pro Controller, Thumb Stick: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling ModRetro M64 Pro Controller, Thumb Stick: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Firmly pull the thumbstick cap straight up to remove it from the press-fit connection.
      • Pinch the top and bottom retaining snap-wings on the thumbstick module, then pull the module straight out from the main gray shell.
      • Put the Thumb Stick cap and module aside.
    11. Disassembling ModRetro M64 Pro Controller, Z Trigger: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling ModRetro M64 Pro Controller, Z Trigger: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling ModRetro M64 Pro Controller, Z Trigger: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Push one side of the Z-trigger hinge pin and pull it out from the opposite side to remove it.
      • Gently pull the membrane from the PCB.
      • To reinstall the membrane, feed the alignment legs through their respective holes. Grip the legs from the other side and pull gently until they are fully seated.
      • Remove the front gray holder
tmai_modretro
crwdns2935283:007/15/26crwdne2935283:0
409 crwdns2915208:0crwdne2915208:0
crwdns2936753:07crwdne2936753:0 47
crwdns2936753:030crwdne2936753:0 180
crwdns2959996:0crwdne2959996:0 1,153
