Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis
  1. Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove serial port connection: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove serial port connection: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove serial port connection: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Loosen the screws on the serial port by turning them counter clockwise by hand.
    • After loosening the screws, pull the serial port out.
  2. Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove Lid: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove Lid: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Remove Lid: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift lid to its vertical position.
    • Pull lid straight up to remove it from the scanner.
  3. Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Detach plastic latches: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Detach plastic latches: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Detach plastic latches: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the plastic opening tools into the crack between the top and the bottom of the chassis.
  4. Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Continue latch detachment: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Continue latch detachment: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Continue latch detachment: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After placing one plastic opening tool into the slit, slide other plastic opening tools along the slit to detach the top from the bottom of the chassis.
    • Go all the way along the chassis until you can lift the upper lid.
  5. Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Fully remove the upper lid: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Fully remove the upper lid: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Disassembling Microtek ScanMaker 5900 Outer Scanner Chassis, Fully remove the upper lid: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Do not fully remove the lid until you remove the ribbon cable attached to the front of the upper lid.
    • Do this by grabbing the upper lid from the sides and rotating it ninety degrees so it is perpendicular to the bottom lid.
    • Grab the ribbon cable and gently pull it out of its slot with your fingers.
    • The upper lid can now safely be removed from the bottom lid.
Taylor Nesheim
crwdns2935283:010/11/11crwdne2935283:0
59 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-9, Regan Fall 2011 crwdns2935289:0Cal Poly, Team 6-9, Regan Fall 2011crwdne2935289:0
CPSU-REGAN-F11S6G9
crwdns2935297:022crwdne2935297:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 2,036
